2950 express setup failure
machasm11
Hi All,
I hope someone may be able to help here.
I cannot get the 2950 to enter into the express setup mode. Nor can I get it to reset by holding down the mode button for 10 secs.
is this feature only available in later versions of IOS?
If so then how do I configure the switch with an ip address for management purposes?
I will try to find out the version of IOS tonight but I think it might be 12.1.11. Does that make any sense?
Thanks.
Mac.
The switch might have express setup disabled via the no setup express command. In which case you can use the same steps for password recovery to get into the switch and configure the information you need, or to re-enable express setup if that is what you want to do.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
Hope that helps.
ohassairi
Level 5
Level 5
do you mean when you connect console cable you get nothing ?
Hi Thanks for the reply
What I mean is that according to the manual I should be able to get the LEDs above the mode button to light up after holding the mode button for 2 secs. This would indicate that the 2950 has entered experss setup mode. I should then be able to connect a pc via a web broswer to 10.0.0.1.
I can't get the LEDs to light up correctly.i.e I can't get the 2950 into express setup mode.
Furthermore, I am unable to reset the 2950 by holding the mode button for greater than 8 secs again in the manual.
If I use a console cable I get a boot sequence after plugging the switch into power. After POST, however, I am unable to access any commands via the console either.
Can you help?
Mac.
Hope that helps.
Thank-you.
That did the trick.
Mac.
