2950 flash space
amit bhatnagar
Hello ,
I was trying to free some space on cico 2950 , whichh has lots of files in flash .
cople of queries
1)please advise which files can be removed
2) can i remove "c2950-hdiag-mz.121-9.EA1" not sure what this is for ?
   2  -rwx         110   Mar 01 1993 00:02:30  info
    3  -rwx     2958970   Mar 01 1993 00:04:01  c2950-i6q4l2-mz.121-14.EA1a.bin
    4  drwx        2304   Mar 01 1993 00:05:04  html
   79  -rwx         110   Mar 01 1993 00:05:07  info.ver
   80  -rwx      335466   Mar 01 1993 00:05:23  c2950-hdiag-mz.121-9.EA1
   81  -rwx        5045   Jun 22 1993 18:23:44  config.text
   82  -rwx         796   Mar 01 1993 00:00:19  vlan.dat
   83  -rwx         341   Jan 01 1970 00:00:22  env_vars
   84  -rwx          47   Jun 22 1993 18:23:44  private-config.text
Thanks for help
Amit
I see the 2.4 Mb free but used space is 3Mb not sure why I cant see 2Mb space
The HTML directory holds files approximately 2 Mb in total size.
Please don't forget to rate our useful posts.
5 Replies 5
Leo Laohoo
Delete everything EXCEPT "c2950-i6q4l2-mz.121-14.EA1a.bin".  This is your IOS.
Thanks for reply Leo ,
Directory of flash:/
7741440 bytes total (2483712 bytes free)
I see the 2.4 Mb free but used space is 3Mb not sure why I cant see 2Mb space , please advise
Thanks for help
regards
Amit
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
It might be your working with a flash formatted such that erased space isn't recovered for deleted files.
Some older Cisco system only supported that flash formatting, but some can be upgraded to the newer flash format if you format (not erase) your flash.  (NB: reformatting you flash will completely erase all its contents, so if you do that, be sure you have some place to store necessary contents so you can restore them.)
thanks fr help
regards
amit
