Webcast-Catalyst9k
2950 QOS problem
Hi dear all,
I want to limit throuput and limit tranfer rate into 16K on L2 cisco switch?
any L2 device suggestion or solution?
Re: 2950 QOS problem
Hi Emadehsan,
You have to use polocing/rate-limiting on 2950 to acheive the same.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12122ea5/2950scg/swqos.htm
Ankur
*Pls rate helpfull post
sho ver of switch pls
Bronze
We get this question a lot in TAC, and the answer is that the 2950 can only police in 1 Mbps increments on fastethernet ports.
The URL is here:
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
Section 2-20 at the top of the page mentions this point. It is also a good design guide for deploying QoS too.
Hope this helps,
Michael
Cisco TAC - LAN Switching
152
