10-26-2017 08:52 AM - edited 03-08-2019 12:30 PM
I am just now diving into COS/QOS and right away, I'm not getting far :( I am messing around on a 2950 switch. Based on what I read, when I enable "mls qos," any marked traffic entering the switch would have those values changed to 0. Is that correct? I have an Avaya VOIP phone attached that marks the DSCP value 46. When I use wireshark and capture that traffic (again, there is no other config on the switch except mls qos,) the DSCP value is still 46!? I thought it would be 0? Any ideas?
mls qos
interface fastethernet0/1
switchport access vlan 110
switchport mode access
switchport voice vlan 112
show mls qos
QoS is enabled
QoS ip packet dscp rewrite is enabled
Solved! Go to Solution.
11-17-2017 11:58 AM
I'm not afraid to show I'm an idiot... I'm back to post what the issue was. I was running wireshark and sniffing the ingress interface (duh!) thus I was seeing the marked traffic. I should have been sniffing the egress interface after the switch remarked the traffic.
10-26-2017 12:34 PM
11-17-2017 11:58 AM
