03-02-2007 08:27 AM - edited 03-05-2019 02:40 PM
03-09-2007 05:53 AM
You must connect the Catalyst 2950G-24-EI-DC switch only to a DC-input power source that has an input supply voltage from -36 to -72 VDC. If the supply voltage is not in this range, the switch might not operate properly or might be damaged.
10-03-2007 02:19 AM
Hi, I want to connect this switch to a 12V power supply, any ideas?
