2960 half duplex trunk to 3560
a switch that connect to my core L3 3560G switch has duplex mismatch.
it is a cisco 2960 and this is the config of the trunk port:
interface GigabitEthernet0/1
description UPLINK to CORE3560G
end
2960_24port#sh int g0/1
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 001b.531a.0c19 (bia 001b.531a.0c19)
Description: UPLINK to CORE3560G
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 3/255
Keepalive set (10 sec)
Half-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1247000 bits/sec, 190 packets/sec
5 minute output rate 60000 bits/sec, 49 packets/sec
631628665 packets input, 1261340809 bytes, 0 no buffer
Received 442225434 broadcasts (0 multicast)
0 watchdog, 72230903 multicast, 0 pause input
155468085 packets output, 316694810 bytes, 0 underruns
0 output errors, 1037074 collisions, 1 interface resets
0 babbles, 377763 late collision, 0 deferred
this is the config on the core side:
interface GigabitEthernet0/45
description uplink to 2960-24port
switchport mode trunk
duplex full
speed 100
spanning-tree portfast
end
CORE3560G#sh int g0/45
GigabitEthernet0/45 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0017.e040.41ad (bia 0017.e040.41ad)
Description: uplink to 2960-24port
reliability 255/255, txload 3/255, rxload 1/255
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
Last input 00:00:08, output 00:00:00, output hang never
5 minute input rate 55000 bits/sec, 46 packets/sec
5 minute output rate 1199000 bits/sec, 191 packets/sec
155179851 packets input, 325907696 bytes, 0 no buffer
Received 1734602 broadcasts (0 multicast)
0 runts, 111 giants, 0 throttles
351695 input errors, 351584 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 1276980 multicast, 0 pause input
631611144 packets output, 1246708284 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
I see the giants and CRC errors and assume they are a result of the duplex mismatch
all other ports on the 2960 are configured in the same way and automatically go to full duplex
Re: 2960 half duplex trunk to 3560
You should hardcode 100/full on both sides if you're going to specify it on one.
HTH,
John
HTH, John *** Please rate all useful posts ***
I assume the second part of my question would be why did it go for the 100MB when both ends are Gig ports
you're saying I must have both ends hard coded?
My mistake:
Try hardcoding both for 1000/full.
John
Purple
Seeing that they are both cisco switches just set both sides speed and duplex as auto and it will negotiate 1000/full on its own . Gig does not need to be hardcoded as a rule at least between cisco devices. I have never seen an instance between cisco devices where it failed to negotiate gig.
They *should* negotiate, but I've seen it where we've had to hardcode it whether it be IOS revisions or other problems that kept it from negotiating the proper duplex.
And you said "Gig does not need to be hardcoded as a rule", but Cisco has always recommended either hardcoding both sides or setting both sides to auto. If auto's not working correctly (which in this case one side was set), then the only other alternative is to try to set both sides manually.
John
You had the following configuration:
at 2960 side: auto
at 3560 side: 100Mb/s, full duplex
As a result, at 2960 side the speed will get the same as at 3560 side: 100Mb/s, but the duplex mode (which can be negotiate only if at both sides the duplex is set to auto) will fall-back to half duplex.
So in order to get rid of the duplex mismatch, either you set the duplex to Auto at both sides or set manually the same duplex mode (full) at both sides.
I've changes only the 3560 side to full\1000 and it fixed the connection on the other side (which is still auto)
That's because at gigabit speeds, the only available duplex option is full.
Personally, I always nail trunk links to a certain speed and duplex, even if gigabit.
at the 2960 it is not optional
even if you type in duplex\speed it will not show it in the config which indicate encoded default
1549
