2960 Help
melwin.uk
On a Remote Site When a switch or hub are connected to switchport, the port needs to be disabled. What configuration is needed on the switch.
The switch is 2960.
Ganesh Hariharan
The switch is 2960.
What i understand from your requirement on switch port if somebody connects another switch or hub then ports goes to disable mode or on some non functioning mode.If yes then configure spanning tree bpdu gaurd on port,If any BPDU is found on the port where BPDU gaurd is enabled then port will automatically move into errdisable state.
Check out the below link for more info on BPDU gaurd
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a008009482f.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Ganesh Hariharan
The switch is 2960.
Hope to Help !!
Ganesh.H
BPDU guard fits the bill in case of switch but in case hub is connected then you will not recieve any BPDU.
I think then you have to opt for port security feature.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_see/configuration/guide/swtrafc.html
Still recommendation is to enable BPDU guard on all the ports along with port security.
Rajat
vvasisth
Configuring BPDU guard will do what you are looking for.
Cisco IOS Software Command
CatSwitch-IOS(config)# spanning-tree portfast bpduguard
When STP BPDU guard disables the port, the port remains in the disabled state unless the port is enabled manually. You can configure a port to reenable itself automatically from the errdisable state. Issue these commands, which set the errdisable-timeout interval and enable the timeout feature:
CatSwitch-IOS(config)# errdisable recovery cause bpduguard
CatSwitch-IOS(config)# errdisable recovery interval 400
Note: The default timeout interval is 300 seconds and, by default, the timeout feature is disabled.
Hope that helps.
Varun
