2960 product clarifications
panvangels
Hello to all,
I need some help concerning the 2960 series switches:
1. the Optical interface option of the Dual Purpose Gigabit Ethernet Uplinks, can also be used as an access port?(ex. connection to a terminal station?)
2. For those forementioned Dual Purpose Gigabit Ethernet Uplinks, optical interfaces are preinstalled or extra hot-swappable SFP Optic converters are needed to be bought?
I would appreciate answers from anyone who really knows...
Thank you in advance,
Panagiotis.
Martin Parry
Level 3
Level 3
These ports can be used as access ports, and unfortunately you will need to purchase SFP modules.
Thanks a lot for your help.
mohammedmahmoud
Level 11
Level 11
Hello Panagiotis,
1.Yes.
2.No, you should buy them exclusively.
http://www.cisco.com/en/US/products/ps6406/products_qanda_item0900aecd80322c37.shtml
HTH,
Mohammed Mahmoud.
Thank you also Mohammed for your help provided.
