2960-S Stack Cable
Quick question....when you order a stacking module with your 2960(S, X) switch, does it come by default with the 0.5m stacking cable?
Also, if you order a 1m stacking cable, does it still come with the 0.5m cable, or does it replace it?
Bobby
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
When you order either a 2960
When you order either a 2960-X or 2960-S with a stacking module, the default in Cisco's ordering system is to include a 0.5m stacking cable.
If the person creating the order instead specifies a 1m (or 3m) cable as part of the parent switch configuration item, it is in place of the default 0.5m cable. Cisco does charge extra for the longer cables.
If you order the cable as a spare part ("=" at the end of the SKU), then it is sold separately and is in addition to any other items in the order.
1 REPLY
143
