09-25-2014 03:20 AM - edited 03-07-2019 08:53 PM
Good morning,
We currently have two 2960 switches in non stacking confguration each with their own config. What I was wondering is what happends if i then stack the two together? Will the config on the secondary be wiped or will it simply merge so any VLAN assignmenets to the prots will they remain or be wiped?
Solved! Go to Solution.
09-25-2014 04:05 AM
Yes, it'll be wiped out. You'll need the 'switch x provison y' command i order to retain the config.
See helpful link:http://wannabelab.blogspot.com/2014/08/cisco-2960s-flexstack-module-and-cable.html?m=0
09-25-2014 04:05 AM
09-25-2014 04:12 AM
Hi Johnlloyd,
Thanks for that link
Cheers
