2960 Switch Console Hangs
Hassan Khawaja
I am having issues with Catalyst 2960 Switch Console. Switch boots up fine and the process shows up on the console. But after the boot-up, console stops responding. It also does not respond to Break sequence at the boot-up. Any solutions? I am using Putty with 9600 8n1 settings.
Hassan
12 Replies 12
Leo Laohoo
Is Flow Control OFF?
I have tried with all settings of flow control, but still no use.
If you see the boot (POST) process on console and then it freezes once booted, then it's probably a baud mismatch in the startup-config.
Parvesh Paliwal
Level 3
Level 3
Welll - the cosole hangs .. what about traffic flow, is it flowing or stopped ?
are the console settings correct at connecting node ?
Parvesh
Remember marking helpful posts.
Traffic is flowing. It just does not accept input from console. Although it shows output from switch in console like when interface goes up or down. And console settings on switch are default. Console was responding fine, it just stopped working out of blue.
Parvesh Paliwal
Level 3
Level 3
Check the settings:
Please confirm if it helps
Parvesh
yeah i have tried these settings, but still not working
have you tried rebooting ?
try switching to a different application putty etc.
yeah multiple times. it boots fine and booting process shows up on console. After that console does not respond
Are you accessing the console over RDP ?
The machine that is connected to the console is being accessed over RDP ?
patelruchit11
Hi Hassan,
Good day,
I too faced the same problem and i tried to download Hyerterminal - there too i faced the same problem.
The system i was using was having OS:Win 2008 R2 x64
Afterwards i tried with a Laptop with Win7 and it worked !
I am not sure at all on the intricacies of this but it did work for me.
Can you please let me know what OS are you using.
Ruchit.
did you solve this issue ?
