2960 Switch with DHCP configured
sgrinnall
we have an issue with a single device picking up DHCP.  PCs on the vLAN are picking up DHCP addresses fine, however another device does not.  If I disable the Cisco DHCP on that vLAN and use an alternative DHCP source, (I downloaded a freebe DHCP server app for my laptop) it works fine.
The DHCP pool is set-up
ip dhcp pool vlan1
   network 192.168.50.0 255.255.255.0
   domain-name Fred.co.uk
   dns-server 192.168.0.150 192.168.0.250
   default-router 192.168.50.254
   lease 3
ip dhcp excluded-address 192.168.50.1 192.168.50.50
ip dhcp excluded-address 192.168.50.60 192.168.50.254
and ports are set up as:-
interface FastEthernet0/2
switchport mode access
spanning-tree portfast
and vLAN 1 as
interface Vlan1
description STORE
ip address 192.168.50.253 255.255.255.0
no ip route-cache
7 Replies 7
sgrinnall
Continued...
I scratching my head on this one, any help is much appreciated
There are only nine addresses available in the pool is that enough?
DHCP-debugging could also give some hints: "deb ip dhcp server events"
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
thanks Karsten.Iwen
yes, 9 is plenty of addesses we are only using this for a couple of devices.
On this device, running "SHO IP DHCP BIND" lists only 2 devices.  I can see the device is connected fine, for example I can see the Mac address of the device with "Sho MAc Address-Table"
I will try the DHCP debugging now
I added the DEB IP DHCP SERVER EVENTS command and can see activity if I release and renew the IP on a PC fine.
Restarting the FalconXT device we have there is no DHCP activity at all.  When using the alternative DHCP server from my PC it picks up an address immediatly
Switch#
*Mar  1 00:06:24.416: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/9, changed state to down
*Mar  1 00:06:25.422: %LINK-3-UPDOWN: Interface FastEthernet0/9, changed state to down
*Mar  1 00:06:32.167: %LINK-3-UPDOWN: Interface FastEthernet0/9, changed state to up
*Mar  1 00:06:32.167: DHCPD: interface FastEthernet0/9 coming up
*Mar  1 00:06:33.174: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/9, changed state to up
*Mar  1 00:06:49.741: DHCPD: checking for expired leases.
Switch#
Switch#
*Mar  1 00:08:49.748: DHCPD: checking for expired leases.
So when releasing/renewing on the device you see no output in debug ip dhcp server event on the switch ?
On which port is this device connected? post the output of sh interface x/x switchport for this interface
Alain
   lease 3
Lease is 3 days????  And you have 8 allowed IP address?  (Personally, I don't see the logic or insanity for this.  If it's only 8 allowable IP addresses and lease time is 3 days, I'd configure the DHCP to be static.)
Post the output to the command "sh ip dhcp bind".
jawad-mukhtar
Level 4
Level 4
Try Giving this command
ip dhcp-server 192.168.50.253
ip dhcp snooping
interface Vlan1
ip helper-address 192.168.50.253
Jawad
Jawad
