01-16-2012 12:03 AM - edited 03-07-2019 04:22 AM
Hi all,
I am trying to configure etherchannel on 2 2960S connected by a flexstack with 2 ports g1/0/52 and g2/0/52 on each 2960.
these switch are connected to a CAT4500, I know that I can only use LACP because of cross-stack but when I force the switch to use LACP witch channel-group 2 Mode active the switch do this :
%With PAgP enabled, all ports in the Channel should belong to the same switch
Command rejected (Port-channel2, Gi1/0/52): Invalid etherchnl mode
% Range command terminated because it failed on GigabitEthernet1/0/52
I don't know how to bundle the 2 ports on the 2960 stack. each time I use : channel-group 2 mode on there is no error
but the switch do this :
*Mar 1 00:45:32.290: %EC-5-CANNOT_BUNDLE2: Gi2/0/52 is not compatible with Po2 and will be suspended (trunk mode of Gi2/0/52 is dynamic, Po2 is trunk)
*Mar 1 00:45:32.531: %EC-5-CANNOT_BUNDLE2: Gi2/0/52 is not compatible with Po2 and will be suspended (trunk mode of Gi2/0/52 is dynamic, Po2 is trunk)
*Mar 1 00:45:32.908: %EC-5-CANNOT_BUNDLE2: Gi2/0/52 is not compatible with Po2 and will be suspended (trunk mode of Gi2/0/52 is dynamic, Po2 is trunk)
*Mar 1 00:45:33.050: %EC-5-CANNOT_BUNDLE2: Gi2/0/52 is not compatible with Po2 and will be suspended (trunk mode of Gi2/0/52 is dynamic, Po2 is trunk)
*Mar 1 00:45:33.286: %EC-5-CANNOT_BUNDLE2: Gi2/0/52 is not compatible with Po2 and will be suspended (trunk mode of Gi2/0/52 is dynamic, Po2 is trunk)
*Mar 1 00:45:33.669: %EC-5-CANNOT_BUNDLE2: Gi2/0/52 is not compatible with Po2 and will be suspended (trunk mode of Gi2/0/52 is dynamic
If you have an idea
thanks
01-16-2012 12:09 AM
Hello Yann,
Please avoid the channel-group mode on at all costs.
Would you care posting either your entire switch stack configuration, or at least the output of the following commands?
show ether sum
show run int gi1/0/52
show run int gi2/0/52
show run int po2
Thank you!
Best regards,
Peter
01-16-2012 12:18 AM
here is what you ask, I will send the configuration later if needed
NEILM-SW00001#sh ether summ
% Ambiguous command: "sh ether summ"
NEILM-SW00001#sh ether summar ?
% Ambiguous command: "sh ether summar "
NEILM-SW00001#sh etherch
NEILM-SW00001#sh etherchannel ?
<1-6> Channel group number
detail Detail information
load-balance Load-balance/frame-distribution scheme among ports in
port-channel
port Port information
port-channel Port-channel information
protocol protocol enabled
summary One-line summary per channel-group
| Output modifiers
NEILM-SW00001#sh etherchannel summ
NEILM-SW00001#sh etherchannel summary ?
| Output modifiers
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
2 Po2(SD) - Gi1/0/52(s) Gi2/0/52(D)
NEILM-SW00001#sh run int g1/0/52
Building configuration...
Current configuration : 105 bytes
interface GigabitEthernet1/0/52
description SW_ETAGE2B_Gig1/0/52-2/0/52
end
NEILM-SW00001#sh run int g2/0/52
interface GigabitEthernet2/0/52
end
NEILM-SW00001#sh run int po2
Current configuration : 233 bytes
interface Port-channel2
switchport trunk native vlan 389
switchport trunk allowed vlan 300-330,389
switchport mode trunk
switchport nonegotiate
load-interval 30
speed nonegotiate
end
01-16-2012 12:28 AM
Hello Yann,
Thank you for the output, and I apologize for posting an incomplete command.
Your physical ports differ in their configuration from the configuration of the Port-channel interface and that is causing the "suspended" messages. A key thing to remember when configuring EtherChannels is that the physical ports and the Port-channel port must be configured identically.
Let us try creating the LACP EtherChannel once again. Please paste the following lines into your configuration (please be aware that this will temporarily shutdown your Gi1/0/52 and Gi2/0/52 interfaces so make sure you do not lose connectivity to your switch):
no interface Port-channel2
interface range Gi1/0/52 , Gi2/0/52
no shutdown
load-interval 30
channel-protocol lacp
channel-group 2 mode active
end
Please keep me informed about the outcome of this configuration change. Also if this does not work as expected, include the same set of command outputs as before.
Best regards,
Peter
01-16-2012 12:45 AM
the behavior seems to be better but the Po2 is still down :
d - default port
2 Po2(SD) LACP Gi1/0/52(I) Gi2/0/52(I)
01-16-2012 12:50 AM
Hello Yann,
This looks good indeed. The "I" state means that our ports are ready to be bundled into EtherChannel but the opposite device did not agree to bundle them using LACP.
Note that the opposite device (the 4500 switch) also has to use LACP in order for this EtherChannel to come up. In a similar way as with 2960, I recommend removing the corresponding Port-channel from the 4500 switch altogether, configuring the physical ports with all necessary commands that formerly appeared on the Port-channel, and then bundling them together into a new Port-channel with LACP.
Good work so far!
Best regards,
Peter
01-16-2012 02:16 AM
hi peter,
thank you for your help but on the other side on the CAT4
Jan 16 10:36:54.114: %EC-5-L3DONTBNDL2: Gi1/2 suspended: LACP currently not enabled on the remote port.
Jan 16 10:37:01.319: %EC-5-L3DONTBNDL2: Gi2/2 suspended: LACP currently not enabled on the remote port.
my port configuration
interface GigabitEthernet1/2
description bundle-etage2B
load-interval 30
speed nonegotiate
channel-group 12 mode active
end
NEILM-CORE00001#sh run int g2/2
Current configuration : 278 bytes
interface GigabitEthernet2/2
load-interval 30
speed nonegotiate
end
NEILM-CORE00001#sh run int po12
Current configuration : 62 bytes
interface Port-channel12
switchport
load-interval 30
end
01-16-2012 10:08 PM
hi,
I didn't have the time to check more but can you tell me why on the other side the 4500 says that the remote port is not LACP configured ?
thanks
01-16-2012 11:08 PM
Hello Yann,
Try adding the switchport command both to Gi1/2 and Gi2/2 interfaces and see what happens.
Best regards,
Peter
01-17-2012 06:45 AM
Hi Yann,
Did you have any luck or progress?
Best regards,
Peter
