01-14-2014 01:45 PM - edited 03-07-2019 05:33 PM
Hello we have a WS-C2960C-12PC-L and it has started crashing recently with reloads with the following syslog:
We have 2 other ones running the same code without crashes
%PLATFORM-1-CRASHED: System previously crashed with the following message:
%PLATFORM-1-CRASHED: Cisco IOS Software, C2960C Software (C2960c405-UNIVERSALK9-M), Version 12.2(55)EX3, RELEASE SOFTWARE (fc2)
%PLATFORM-1-CRASHED: Technical Support: http://www.cisco.com/techsupport
%PLATFORM-1-CRASHED: Copyright (c) 1986-2011 by Cisco Systems, Inc.
%PLATFORM-1-CRASHED: Compiled Wed 10-Aug-11 06:40 by prod_rel_team
%PLATFORM-1-CRASHED: Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
%PLATFORM-1-CRASHED: SRR0 = 0x013213DC SRR1 = 0x00029230 SRR2 = 0x01704198 SRR3 = 0x00029230
%PLATFORM-1-CRASHED: ESR = 0x00000000 DEAR = 0x00000000 TSR = 0x84000000 DBSR = 0x10000000
%PLATFORM-1-CRASHED: CPU Register Context:
%PLATFORM-1-CRASHED: Vector = 0x00002000 PC = 0x01704198 MSR = 0x00029230 CR = 0x30000003
%PLATFORM-1-CRASHED: LR = 0x0170415C CTR = 0x0096196C XER = 0xC000007E
%PLATFORM-1-CRASHED: R0 = 0x0170415C R1 = 0x02865B48 R2 = 0x00000000 R3 = 0x030F54F8
%PLATFORM-1-CRASHED: R4 = 0xFFFFFFFE R5 = 0x00000000 R6 = 0x02865B30 R7 = 0x00000000
%PLATFORM-1-CRASHED: R8 = 0x00000000 R9 = 0x00000000 R10 = 0x02160000 R11 = 0x030F54F4
%PLATFORM-1-CRASHED: R12 = 0x0000001C R13 = 0x00110000 R14 = 0x00D6DFB8 R15 = 0x00000000
%PLATFORM-1-CRASHED: R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
%PLATFORM-1-CRASHED: R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x02160000
%PLATFORM-1-CRASHED: R24 = 0xAB1234AB R25 = 0x06C19FA0 R26 = 0x00000000 R27 = 0x02326204
%PLATFORM-1-CRASHED: R28 = 0x00000001 R29 = 0x01B19040 R30 = 0x06C19FA0 R31 = 0x00000000
%PLATFORM-1-CRASHED: Stack trace:
%PLATFORM-1-CRASHED: PC = 0x01704198, SP = 0x02865B48
%PLATFORM-1-CRASHED: Frame 00: SP = 0x02865B58 PC = 0x0170415C
%PLATFORM-1-CRASHED: Frame 01: SP = 0x02865B88 PC = 0x00D6AA80
%PLATFORM-1-CRASHED: Frame 02: SP = 0x02865BA0 PC = 0x00D6A670
%PLATFORM-1-CRASHED: Frame 03: SP = 0x02865BD8 PC = 0x00D6B304
%PLATFORM-1-CRASHED: Frame 04: SP = 0x02865BF0 PC = 0x00D6DE48
%PLATFORM-1-CRASHED: Frame 05: SP = 0x02865C08 PC = 0x00D6E058
%PLATFORM-1-CRASHED: Frame 06: SP = 0x02865C10 PC = 0x01706168
%PLATFORM-1-CRASHED: Frame 07: SP = 0x00000000 PC = 0x016FCBD8
01-14-2014 01:54 PM
It appears you have memory issues with this device. If you have 2 other device the same as this one and the IOS is the same for all 3, than I would open a ticket witch Cisco and RMA this one.
01-14-2014 02:13 PM
Is there anyway to confirm this through the CLI?
01-14-2014 03:26 PM
12.2(55)EX3
Be aware that the IOS you are using is classified as an Interim Software. The main objective is to get this model working temporarily while the IOS is still being developed. It is NOT designed to be used in long-term production.
I would recommend you consider upgrading to 15.0(2)SE4. Do not attempt to download and use other IOS, such as 15.0(2)SE5 or 15.2(1)E or 15.2(1)E1 or you'll be left in tears.
01-15-2014 10:35 AM
But the other two are not experiencing the problem, do you think the IOS could be causing it?
01-15-2014 01:30 PM
Not sure. The only time you'll find the "EX" IOS in our premises is when the appliances are in a newly-delivered sealed box. I won't and don't have the "EX" IOS anywhere in my network.
01-27-2014 11:56 AM
After upgrading the IOS it seems like it has stopped crashing
Thank you for the help
