05-09-2014 10:41 PM - edited 03-07-2019 07:24 PM
How can I make2960S stack numbering unchanged after power-on?
I apply stack-master highest priority (14)
After power-up sometimes Master Switch number becomes #2 or #3 or #4
sw#sh switch detail
Switch/Stack Mac Address : c025.5ccf.7c00
H/W Current
Switch# Role Mac Address Priority Version State
*1 Master c025.5ccf.7c00 14 1 Ready
2 Member 64e9.5055.da80 1 1 Ready
3 Member 64e9.5055.ca80 1 1 Ready
4 Member 64e9.5082.5180 1 1 Ready
Stack Port Status Neighbors
Switch# Port 1 Port 2 Port 1 Port 2
1 Ok Ok 4 2
2 Ok Ok 1 3
3 Ok Ok 2 4
4 Ok Ok 3 1
THANKS
05-09-2014 11:54 PM
You mean after a power-up, Master Switch does not have a "*" and the "*"* goes to either #2 or #3 or #4?
05-10-2014 01:10 AM
When I first power sw#1 first than , others conseguently, no problem
But after a power problem, I dont konow which sw becomes first, I cannot reac the stack by telnet
This site is remote, I cannot telnet the sw,
Backbone connection is by sw#1 s fiber port
I want stack numbering does not change according to power-up sequence
Also port numbering mus not change
Always upper switch ports must remain same such: #gig 1/0/.
Thanks a lot
05-10-2014 07:13 AM
Ok. The behaviour is normal. Unless the entire stack powered up simultaneously or the master was powered up first, the switch master can be the first unit to be powered up (even though switch priority is configured).
The only way out is to reboot the entire stack or the three switches.
