09-10-2013 02:07 AM - edited 03-07-2019 03:22 PM
We have the following error logs on our switch:
Switch#sh log
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 1836 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 42261523 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 236 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 42259687 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 5882 message lines logged
Log Buffer (4096 bytes):
1:14: -Traceback= 11AA5D0 119BA64 119CF38 10C08F0 10C0B14 10C1680 114E36C 115E060 115DDB8 1152384 114E868 1144574 1144E64 1857368 184DDE0 (Switch-4)
Sep 10 09:01:14: platform assert failure: 0: ../src-hulc/src-common/hulc_mad_sd_mgr.c: 655: hmsm_l3_get_locked_mad (Switch-4)
Sep 10 09:01:14: -Traceback= 11AA5D0 119BA64 119CF38 10C08F0 10C0B14 10C1680 114E36C 115E060 115DDB8 1152384 114E868 1144574 1144E64 1857368 184DDE0 (Switch-4)
Sep 10 09:01:18: platform assert failure: 0: ../src-hulc/src-common/hulc_mad_sd_mgr.c: 655: hmsm_l3_get_locked_mad (Switch-4)
Sep 10 09:01:18: -Traceback= 11AA5D0 119BA64 119CF38 10C08F0 10C0B14 10C1680 114E36C 115E060 115DDB8 1152384 114E868 1144574 1144E64 1857368 184DDE0 (Switch-4)
Switch#
Also find attached the show ver output.
Any ideas?
TIA,
Nicos Nicolaides
Solved! Go to Solution.
09-10-2013 02:35 AM
Nicos,
The traceback leads to the Bug. Kindly plan for the software upgrade.
If you want the bug details kindly lot the Cisco tac case.
regards
Inayath
**********plz rate if this info is helpfull.
09-10-2013 02:35 AM
Nicos,
regards
Inayath
