Webcast-Catalyst9k
2fe2w card is not found in 2611 router
Hi !
I just installed the card 2fe2w to the router and the router did not find fastethernet port installed on it !
here show version
Router#sh vers
IOS (tm) C2600 Software (C2600-IK9O3S3-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 15:23 by dchih
ROM: System Bootstrap, Version 11.3(2)XA2, PLATFORM SPECIFIC RELEASE SOFTWARE (fc1)
Router uptime is 9 minutes
System image file is "flash:c2600-ik9o3s3-mz.123-26.bin"
output cut
cisco 2611 (MPC860) processor (revision 0x200) with 61440K/4096K bytes of memory.
M860 processor: part number 0, mask 32
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
and here sh diag output we see adapter
Router#sh diag
Slot 0:
        C2611 2E Mainboard Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Hardware Revision        : 2.0
        Part Number              : 73-2840-06
        RMA History              : 00
        RMA Number               : 0-0-0-0
        Board Revision           : A0
        Deviation Number         : 0-0
        Product (FRU) Number     : C2611 - 2E
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 00 92 41 02 00 C1 18 4A 41 42 30 32 33
          0x10: 32 30 31 47 4C 20 28 31 30 31 33 34 36 36 39 37
          0x20: 34 29 82 49 0B 18 06 04 00 81 00 00 00 00 42 41
          0x30: 30 80 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 1:
        Unknown (type 216) Port adapter
        Port adapter is disabled
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-04797-01
        Board Revision           : G0
        Fab Version              : 05
        RMA Test History         : 00
        RMA History              : 00
        Product (FRU) Number     : NM-2FE2W=
          0x00: 04 FF 40 00 D8 41 01 00 C0 46 03 20 00 12 BD 01
          0x10: 42 47 30 80 00 00 00 00 02 05 C1 8B 4A 41 44 30
          0x20: 35 34 37 30 50 57 39 03 00 81 00 00 00 00 04 00
          0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
What Should I do to make my adapter reconnized ?
Hall of Fame Super Gold
VIP Super Bronze
Re: 2fe2w card is not found in 2611 router
In addition to what Leo noted, if you need 10/100 ports, get a 2621.  It comes with two by default.
Reza
+5 Reza.
VIP Super Bronze
Leo,
Thanks for the rating
Reza
526
