3500 XL IOS upgrdation
Hi all,
Can any one tells me how to do IOS upgrdation on 3524 XL switch
thanks in advance
Patil
1 ACCEPTED SOLUTION
Re: 3500 XL IOS upgrdation
HI
First u need to delete the below files from the flash.
c3500xl-c3h2s-mz.120-5.WC14.bin
c3500XL-hdiag-mz-120.5.3.WC.1
after deleting the files dnot restart the switch and after that u can follow the normal tftp procedure.
after the image is copied set the boot path
boot system flash:imagename.
Mahmood
Hall of Fame Super Silver
Hello Patil,
you can find the procedure here
www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800946e5.shtml')">http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800946e5.shtml
the tftp procedure is the one typically used.
you need a TFTP server on your PC.
be aware that the switch is in EOS.
To download a suitable IOS image for it you may need to go from
www.cisco.com
quick links -> documentation
then you select end of sale end of support products
go to the switches section and select 3500 XL
or you go directly to
http://www.cisco.com/en/US/products/hw/switches/ps637/tsd_products_support_eol_series_home.html
you need a CCO account with enough privileges and associated to a valid contract that includes the C3500XL platform to be able to download
Hope to help
Giuseppe
Dear
Thanks very much for the update.
I have already done it for 12 stack Switches but i have problem with 3524 XL switches
#sh fla
001M1#sh flash:
Directory of flash:/
2 drwx 704 Mar 01 1993 00:03:08 html
4 -rwx 109 Mar 01 1993 00:01:37 info
5 -rwx 1811003 May 12 1993 00:26:06 c3500xl-c3h2s-mz.120-5.WC14.bin
16 -rwx 109 Mar 01 1993 00:03:08 info.ver
17 -rwx 94375 Mar 01 1993 00:03:24 c3500XL-hdiag-mz-120.5.3.WC.1
19 -rwx 1852 Nov 07 2008 14:45:29 vlan.dat
20 -rwx 355 May 12 1993 00:24:20 env_vars
21 -rwx 6474 Nov 25 2008 15:49:45 config.text
3612672 bytes total (294400 bytes free)
#tar ?
/table List files in tar file
/xtract Extract files in tar file
M1#tar /x ?
WORD Tar filename
ATLFAC2001M1#tar /x
I am not sure and confused how to upgrade from TFTP, could you please tell me in steps
Thanks very much for great help
Patil
HI
Mahmood
Thanks for the update
normal copy tftp flash commda works for this 3524 XL switch since every document talks about tar file
thanks
Patil
Dear All,
Thanks very much for all,
Have done with IOS upgrdation on 3500 XL switches, Please find the logs as attahcment
regards
Patil
hello,
I hope this helps:
1. Install TFTP on your system (say desktop).
2. Download the required IOS & save it on your desktop (location where your TFTP server is present)
3. While downloading the IOS image from Cisco, please make a note of the MD5 value present.
4. Telnet to the switch (you can configure it via console as well) & give the command :
copy tftp: flash:
This will prompt the follwing:
Source filename []? xxxxx.bin (provide the image name stored on your desktop)
Address or name of remote host []? xx.xx.xx.xx (your system IP address)
Destination filename [] ? xxxxx.bin (Same name as the source filename to be provided)
5. Now, the copying will start & will take some time. Once it is copied, it will mention as copying is done.
6. give 'dir' command and check if you see the new image preset.
7. verify the IOS (Ex: verify bootflash:xxxx.bin)
8. verify /md5 bootflash:xxxxxx.bin
(ensure that this md5 value is the same as the one obtained while downloading the image from Cisco)
Change the boot sequence & save the configurations. Once done, reload the switch & verify if the switch has booted up with the new image.
797
