Community Member
3500xl switch problem - switch: prompt
my IOS got deleted from CAT 3500XL switch
I have copy of the IOS on my TFTP server
when I start the switch I get the following:
C3500XL Boot Loader (C3500-HBOOT-M) Version 12.0(5)XU, RELEASE SOFTWARE (fc1)
Compiled Mon 03-Apr-00 17:47 by swati
starting...
Base ethernet MAC Address: 00:02:b9:5a:01:c0
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 3 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 3612672
flashfs[0]: Bytes used: 255488
flashfs[0]: Bytes available: 3357184
flashfs[0]: flashfs fsck took 2 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
The system is unable to boot automatically because there
are no bootable files to boot.
switch:
switch: dir flash:
Directory of flash:/
3 drwx 128 <date> lost+found
4 -rwx 3 <date> env_vars
3357184 bytes available (255488 bytes used)
switch: copy tftp://c3500xl-c3h2s-mz.120-5.WC17 flash
tftp://c3500xl-c3h2s-mz.120-5.WC17: permission denied
how do I get the IOS loaded to the switch?
(I'm using console cable)
Community Member
Re: 3500xl switch problem - switch: prompt
also tried this:
switch: flash_init
...The flash is already initialized.
switch: copy xmodem: flash:c3550-i5q3l2-mz.121-19.EA1a.bin
Begin the Xmodem or Xmodem-1K transfer now...
CCCCCCCCCCBB0BB0xmodem:: I/O error
switch:
and when I try to send it via HyperTerminal I get "no response from remote server"
switch: BB0BB0
Community Member
fixed it with http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/releasesa4/rn/OL013501.html#wp6605
the part I missed was doing teh hyperTerminal while Xmodem start
367
