3550 and access-group command
Hi all. Can you not use the access-group command on a 3550 switch with ipservices IOS on it? I can create an access-list, but can seem to apply it to an vlan interface or routed interface. Anyone have any thoughts?
Re: 3550 and access-group command
It is supported on the IP services image and you should be able to apply access-group on the routed interface. You can create VACLS to set the filtering on the vlan interface. Please find the link below for the creating security acls on 3550:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12225seb/scg/swacl.htm#wp1107203
Please paste " show version " and "show run " from your switch, if you still face any problem.
HTH,
-amit singh
Silver
Make sure you are entering the right command it should be "ip access-group ACL_NAME in"
Let me know how it goes,
I mistyped. Thanks.
Silver
Glad I could help and thanks for the rating.
217
