Webcast-Catalyst9k
3550 and speed 10
I have a link between 3550 (12.1(19)EA1a) and a Operator's switch C2924M-XL (12.0(5.2)XU) .
Before the speed between the 2 switchs was 100M/Full but we have modify in 10M/full. But now we have some errors and crc on the 3550's interface and not on 2924's interface.
Could you help me to resolve this problem.
Best regards
1 REPLY
Re: 3550 and speed 10
When connecting 2 Cisco interfaces togather you should consider to leave it on auto speed and auto duplex. But if you want to fix the speed/duplex then you must do on both ends.
I have also noticed your IOS on both switches are very old, consider an IOS upgrade. To download the IOS from Cisco.com you will need a CCO account or you may need to speak to your Hardware supplier/Cisco partner.
Shaheen
109
