04-10-2014 06:03 PM - edited 03-07-2019 07:03 PM
I'm trying to create a vlan on a 3550. the vlan parameter is not showing under config. I've created vlans on this switch before. any ideas??? am I missing something obvious?
Switch(config)#?
Configure commands:
aaa Authentication, Authorization and Accounting.
access-list Add an access list entry
alias Create command alias
arp Set a static ARP entry
banner Define a login banner
boot Boot Commands
buffers Adjust system buffer pool parameters
cdp Global CDP configuration subcommands
cgmp Global CGMP configuration commands
class-map Configure QoS Class Map
clock Configure time-of-day clock
cluster Cluster configuration commands
default Set a command to its defaults
default-value Default character-bits values
downward-compatible-config Generate a configuration compatible with older
software
enable Modify enable password parameters
end Exit from configure mode
errdisable Error disable
exception Exception handling
exit Exit from configure mode
file Adjust file system parameters
help Description of the interactive help system
hostname Set system's network name
interface Select an interface to configure
ip Global IP configuration subcommands
line Configure a terminal line
logging Modify message logging facilities
mac-address-table Configure the MAC address table
map-class Configure static map class
map-list Configure static map list
mvr Enable/Disable MVR on the switch
no Negate a command or set its defaults
ntp Configure NTP
policy-map Configure QoS Policy Map
power power configuration
priority-list Build a priority list
privilege Command privilege parameters
queue-list Build a custom queue list
rmon Remote Monitoring
scheduler Scheduler parameters
service Modify use of network based services
shutdown Shutdown system elements
snmp-server Modify SNMP parameters
spanning-tree Spanning Tree Subsystem
stackmaker Specify stack name and add its member
tacacs-server Modify TACACS query parameters
tftp-server Provide TFTP service for netload requests
time-range Define time range entries
udld Configure global UDLD setting
username Establish User Name Authentication
vmps VMPS settings
vtp Configure global VTP state
Switch(config)#vlan 50
% Invalid input detected at '^' marker.
Switch(config)#
Solved! Go to Solution.
04-10-2014 08:24 PM
04-10-2014 08:24 PM
Switch# vlan database
vlan 50
name BLAH
exit
