04-16-2009 09:55 AM - edited 03-06-2019 05:13 AM
ok, I may be missing something simple, but I have 2 3550's no ip routes, no default gateway set, no dns servers set, yet I can ping outside addresses, traceroute to them and resolve names miraculously, any ideas where these default routes might be coming from
interface Vlan30
ip address 10.20.30.21 255.255.255.0
interface Vlan39
ip address 10.20.39.12 255.255.255.0
ip classless
ip http server
control-plane
line con 0
line vty 0 4
password 7 070A20581D0C1C09
login
line vty 5 15
password 7 02050D480809
no login
end
ussw01#sho ip route
Default gateway is not set
Host Gateway Last Use Total Uses Interface
ICMP redirect cache is empty
ussw01#
04-16-2009 11:13 AM
Mike,
Do you think reloading C3550 will solve this issue? (grin)
Don't forget to post the output I asked for If you're available to do that.
Toshi
04-16-2009 11:18 AM
no as it is happening on two switches. odds of same glitch is small
04-16-2009 11:43 AM
Hey, now that I got the 2 of you guys here, check this out for a sec:
I have a switch access port configured for switchport voice vlan 580.
Then I have the SVI for 580.
Then I plug the laptop into the switchport and try to PING SVI. Doesnt work.
When I remove the voice vlan command and make it a regular data vlan (switchport access vlan 580), it works.
Im wondering why. Have you encountered this before?
Taking a guess, I would think that the voice vlan command lets the switchport expect a voice packet with voice signalling information in the header. When it doesnt see that, it just kills the packet.
IS that what you think is happening?
Victor
04-16-2009 11:45 AM
i think that your laptop isn't sending cdp so switchport doesnt' recognize a cisco phone on the end so doesnt use voice vlan.
04-16-2009 11:53 AM
Victor,
My turn, I think that switch is waiting for tagged packets and then untag it before sending it out to SVI(voice). Your pc can tag packets. NO! Voice Vlan? That's why IP-Phone has to do some with the packets to separate data(untagged) vlan and voice vlan.
Toshi
04-16-2009 12:01 PM
the way that the switch determines to use the voice vlan is that it recognizes a cisco ip phone via cdp, no phone, no voice vlan. yes your pc can tag packets, but unless the switch sees an ip phone plugged in via cdp it wont use the voice vlan and the port will stay and access port.
04-16-2009 12:08 PM
MIKE,
Please correct me if I'm wrong. I used to do the following commands with Avaya IP phone. Well, Don't get me wrong. I indeed love cisco ip phone.
Interface f0/1
switchport mode access
switchport access vlan 100
switchport voice vlan 300
Well,Avaya will not know about cdp. What it does is that it will tag voice packets and leave data traffic as untag and send them to the switch.
Toshi
04-16-2009 12:10 PM
what do you get when you show cdp neighbors
04-16-2009 12:17 PM
Mike,
I got nothing from cdp but interface is up and works like a charm. I think that CDP is pretty cool for cisco ip phone. IP-Phone will learn about you already configured. That's cool. Avaya engineer(not me(grin)) has to manually configure voice vlan on the avaya phone itself to tell it. Part of data traffic will depend on what we configured at the port because they are coming with untagged packets.
Toshi
04-16-2009 12:24 PM
I was under the impression that the cisco switch wouldn't use the voice vlan unless it saw a phone via cdp, but the avaya gets its voice vlan via manual config or dhcp, so maybe as long as the device attached supports q tagging it will work. That would also mean that his laptop would have to have a nic that supported 802.1q tagging otherwise would be put in data vlan. I am verifying about the switchport
04-16-2009 12:28 PM
Mike,
You're right.
Off topic, My country many customers use Avaya and Nortel. What about yours? and how are you doing? (grin)
Toshi
04-16-2009 12:36 PM
yes a lot use avaya and nortel and my issue is resolved. proxy arp was enabling the routing and the ip domain lookup to the 255.255.255.255 was resolving the names.
04-16-2009 12:44 PM
Mike,
That's great. But I'm a bit confused. I'm not sure that why the switches do ARP for 4.2.2.1. Am I missing something?
Toshi
04-16-2009 02:50 PM
"proxy arp was enabling the routing"
Ehem...seems like someone suggested that at the beginning of this thread. Gee, I wonder who it was. ;-)
I'll take my 5 POINTS now...from BOTH of you...
Thank you...thank you (blowing kisses to an endearing crowd)
