Community Member
3550 PBR
Dear Reader,
I have a L3 3550 (12.1) running OSPF, we are planning an enterprise wide IP migration. I need to route my traffic now based on source address, Legacy and new address space.
I have a route map functioning using the ?set ip next-hop? command. Which works as it is supposed to.
However I still need to take into account the OSPF routes.
Therefore I understand that the command I need to use is the 'set ip default next-hop' to allow packets to be routed using the routing table when specifically matched. However, I also know that this command is not supported by the catalyst 3550.
Can anyone please let me know of any alternative method if one exists to achieve the same result?
Thanks in anticipation
1 REPLY
Community Member
Re: 3550 PBR
Any ideas anyone, before i write this off and use a 2821 instead.
175
