Webcast-Catalyst9k
3550 Problem resetting the configurations - Please help!
I'm trying to integrate a couple of 3550's into our current network and need some help resetting their IP's. The instructions from the Cisco guide are not working, as when I press and hold the "Mode" button, nothing happens.
Has anyone else had this problem and does anyone know what might work?
1 REPLY
Re: 3550 Problem resetting the configurations - Please help!
It sounds like the express setup might be disabled in the switch. If express setup is disabled Mode button doesn't work.
http://www.cisco.com/en/US/customer/docs/switches/lan/catalyst3550/software/release/12.1_14_ea1/command/reference/cli2.html
Sundar
139
