3550 Switch and 1130 Access Point using Q-in-Q results in one-way traffic - why?
I have a standalone Cisco 1130 running 12.4(10b)JA3 configured like this (excluding the WPA2-Enterprise authentication stuff, which works fine):
dot11 ssid Maintenance-WORKSTATION2
   vlan 102
   authentication open eap EAP_WS02
   authentication network-eap EAP_WS02
   authentication key-management wpa version 2
interface Dot11Radio0
encryption vlan 102 mode ciphers aes-ccm
interface Dot11Radio0.102
encapsulation dot1Q 102
no ip route-cache
bridge-group 102
bridge-group 102 subscriber-loop-control
bridge-group 102 block-unknown-source
no bridge-group 102 source-learning
no bridge-group 102 unicast-flooding
bridge-group 102 spanning-disabled
interface FastEthernet0.102
encapsulation dot1Q 802 second-dot1q 220
no ip route-cache
bridge-group 102
interface BVI102
no ip address
no ip route-cache
FastEthernet0 on the 1130 is connected to a 3550 switch on port fa0/46...
system mtu 1504
interface FastEthernet0/46
switchport trunk native vlan 40
switchport trunk allowed vlan 40,801-813
switchport mode trunk
...and I have a Linux server port eth0 attached to this same 3550 on port fa0/2:
interface FastEthernet0/2
switchport access vlan 802
switchport mode dot1q-tunnel
no cdp enable
spanning-tree portfast
end
The Linux server has these interfaces:
eth0: 10.128.1.19/29
eth0.220: 172.20.30.1/24
I can authenticate a laptop to SSID Maintenance-WORKSTATION2 with no problem.  The laptop has static IP address 172.20.30.201/24.  I cannot ping 172.20.30.1 from the laptop.  Wireshark on the laptop shows ARP requests for 172.20.30.1 going out, but no replies.  When I attempt to ping 172.20.30.201 from the Linux server, I see the ARPs go out eth0.220 through the switch and AP and arrive at the laptop, and the laptop replies with an ARP response, but the response does not reach the Linux server.  So, traffic seems to flow in only one direction.  Why would this be?
Thanks and regards,
Steve
Everyone's tags (4)
133
