05-04-2014 11:42 AM - edited 03-07-2019 07:19 PM
Hi..
I have recently added a 3550 switch in my network. This switch Fastehernet port connect to distribution switch 2960 Gigabit port. Fastethernet port configured with trunk and dot1Q encapsulation and 2960 Gig port is with trunk only. When i connect a PC on 3550 switch i cannot ping my gateway.
Gateway IP are configured on my core(4500) switch. We have other 2960 switches connected to distribution and dont find issue with it.
Pls suggest where i am doing wrong.
05-04-2014 12:43 PM
Can you issue
sh interface trunk
on both 3550 and the 2960 to make sure the interfaces are configured as dot1.q?
Can you post it here?
also, can you post "sh run" from both switches?
What is the PC vlan id on the 3550?
did you add the vlan to the port?
did you add the PC vlan id to the trunk between the 2960 and the 4500 switch?
05-04-2014 01:16 PM
Hi.. Pls see below config & and int trunk output. PC is connected on 184 vlan on 3550 switch. I can ping everything from 3550 switch.but when i connect PC on this switch and give vlan 184 ip then i can not even ping gateway.Though i can ping 184 vlan gateway from 3550 switch.
3550#sh int trunk
Port Mode Encapsulation Status Native vlan
Fa0/24 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa0/24 1-4094
Port Vlans allowed and active in management domain
Fa0/24 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Port Vlans in spanning tree forwarding state and not pruned
2960-G#sh int trunk
Gi0/1 on 802.1q trunking 1
Gi0/2 on 802.1q trunking 1
Gi0/3 on 802.1q trunking 1
Gi0/4 on 802.1q trunking 1
Gi0/5 on 802.1q trunking 1
Gi0/6 on 802.1q trunking 1
Gi0/7 on 802.1q trunking 1
Gi0/8 on 802.1q trunking 1
Gi0/9 on 802.1q trunking 1
Gi0/10 on 802.1q trunking 1
Gi0/11 on 802.1q trunking 1
Gi0/12 on 802.1q trunking 1
Gi0/13 on 802.1q trunking 1
Gi0/14 on 802.1q trunking 1
Gi0/15 on 802.1q trunking 1
Gi0/16 on 802.1q trunking 1
Gi0/17 on 802.1q trunking 1
Gi0/19 on 802.1q trunking 1
Gi0/20 on 802.1q trunking 1
Gi0/24 on 802.1q trunking 1
Gi0/1 1-4094
Gi0/2 1-4094
Gi0/3 1-4094
Gi0/4 1-4094
Gi0/5 1-4094
Gi0/6 1-4094
Gi0/7 1-4094
Gi0/8 1-4094
Gi0/9 1-4094
Gi0/10 1-4094
Gi0/11 1-4094
Gi0/12 1-4094
Gi0/13 1-4094
Gi0/14 1-4094
Gi0/15 1-4094
Gi0/16 1-4094
Gi0/17 1-4094
Gi0/19 1-4094
Gi0/20 1-4094
Gi0/24 1-4094
Gi0/1 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/2 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/3 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/4 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/5 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/6 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/7 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/8 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/9 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/10 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/11 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/12 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/13 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/14 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/15 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/16 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/17 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/19 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/20 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Gi0/24 1,11-12,24,29,32,36,40,96,99-102,112,119,129-132,136,144-145,147-148,150,152,155,158-161,163,165,168,176-177,180-181,184,190,208-211,215-216,220,226,255,280
Config--
2960-G-Distribution
interface GigabitEthernet0/1
description >> connected to xxx <<
switchport mode trunk
interface GigabitEthernet0/2
description >> connected to xxx<<
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
spanning-tree portfast
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
switchport access vlan 180
interface GigabitEthernet0/23
interface GigabitEthernet0/24
description >> connected to Core-4500 <<
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan176
ip address 192.168.176.201 255.255.255.0
no ip route-cache
ip default-gateway 192.168.176.254
ip http server
logging trap warnings
3550 switch-config
interface FastEthernet0/1
switchport access vlan 184
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
switchport voice vlan 155
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
no ip address
shutdown
interface Vlan176
ip address 192.168.176.105 255.255.255.0
interface Vlan184
no ip address
05-04-2014 01:40 PM
Did you create the layer-2 vlan (184) on the 3550 switch.
config t
vlan 184
name data-vlan
exit
and test again from the PC?
sh vlan summary
05-04-2014 02:19 PM
Hi... I already tried this and did this agian but no luck. Its not working.
05-04-2014 03:04 PM
Can you post the output of "sh vlan summary"
05-04-2014 03:10 PM
Hi. See below
3550#sh vlan summ
Number of existing VLANs : 54
Number of existing VTP VLANs : 54
Number of existing extended VLANs : 0
my one concern is..can trunking between FastEthernet & Gigabit configured and working??
05-04-2014 03:16 PM
As long the interface is up and running, it should work. since one switch is 100 and the other is gig, they negotiate at 100
Sorry can you post "show vlan"?
05-04-2014 03:37 PM
pls see below..
3550#sh vlan
VLAN Name Status Ports
1 default active Gi0/1, Gi0/2
11 VLAN0011 active
12 VLAN0012 active
24 VLAN0024 active
29 VLAN0029 active
32 VLAN0032 active
36 VLAN0036 active
40 VLAN0040 active
96 VLAN0096 active
99 VLAN0099 active
100 VLAN0100 active
101 VLAN0101 active
102 VLAN0102 active
112 VLAN0112 active
119 VLAN0119 active
129 VLAN0129 active
130 VLAN0130 active
131 VLAN0131 active
132 VLAN0132 active
136 VLAN0136 active
144 VLAN0144 active
145 VLAN0145 active
147 VLAN0147 active
148 VLAN0148 active
150 VLAN0150 active
152 VLAN0152 active
155 VLAN0155 active
158 VLAN0158 active
159 VLAN0159 active
160 VLAN0160 active
161 VLAN0161 active
163 VLAN0163 active
165 VLAN0165 active
168 VLAN0168 active
176 VLAN0176 active
177 VLAN0177 active
180 VLAN0180 active
181 VLAN0181 active
184 VLAN0184 active Fa0/1, Fa0/2, Fa0/3, Fa0/4, Fa0/5, Fa0/6, Fa0/7, Fa0/8, Fa0/9, Fa0/10, Fa0/11, Fa0/12, Fa0/13, Fa0/14, Fa0/15, Fa0/16
Fa0/17, Fa0/18, Fa0/19, Fa0/20, Fa0/21, Fa0/22, Fa0/23
190 VLAN0190 active
208 VLAN0208 active
209 VLAN0209 active
210 VLAN0210 active
211 VLAN0211 active
215 VLAN0215 active
216 VLAN0216 active
220 VLAN0220 active
226 VLAN0226 active
255 VLAN0255 active
280 VLAN0280 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
11 enet 100011 1500 - - - - - 0 0
12 enet 100012 1500 - - - - - 0 0
24 enet 100024 1500 - - - - - 0 0
29 enet 100029 1500 - - - - - 0 0
32 enet 100032 1500 - - - - - 0 0
36 enet 100036 1500 - - - - - 0 0
40 enet 100040 1500 - - - - - 0 0
96 enet 100096 1500 - - - - - 0 0
99 enet 100099 1500 - - - - - 0 0
100 enet 100100 1500 - - - - - 0 0
101 enet 100101 1500 - - - - - 0 0
102 enet 100102 1500 - - - - - 0 0
112 enet 100112 1500 - - - - - 0 0
119 enet 100119 1500 - - - - - 0 0
129 enet 100129 1500 - - - - - 0 0
130 enet 100130 1500 - - - - - 0 0
131 enet 100131 1500 - - - - - 0 0
132 enet 100132 1500 - - - - - 0 0
136 enet 100136 1500 - - - - - 0 0
144 enet 100144 1500 - - - - - 0 0
145 enet 100145 1500 - - - - - 0 0
147 enet 100147 1500 - - - - - 0 0
148 enet 100148 1500 - - - - - 0 0
150 enet 100150 1500 - - - - - 0 0
152 enet 100152 1500 - - - - - 0 0
155 enet 100155 1500 - - - - - 0 0
158 enet 100158 1500 - - - - - 0 0
159 enet 100159 1500 - - - - - 0 0
160 enet 100160 1500 - - - - - 0 0
161 enet 100161 1500 - - - - - 0 0
163 enet 100163 1500 - - - - - 0 0
165 enet 100165 1500 - - - - - 0 0
168 enet 100168 1500 - - - - - 0 0
176 enet 100176 1500 - - - - - 0 0
177 enet 100177 1500 - - - - - 0 0
180 enet 100180 1500 - - - - - 0 0
181 enet 100181 1500 - - - - - 0 0
184 enet 100184 1500 - - - - - 0 0
190 enet 100190 1500 - - - - - 0 0
208 enet 100208 1500 - - - - - 0 0
209 enet 100209 1500 - - - - - 0 0
210 enet 100210 1500 - - - - - 0 0
211 enet 100211 1500 - - - - - 0 0
215 enet 100215 1500 - - - - - 0 0
216 enet 100216 1500 - - - - - 0 0
220 enet 100220 1500 - - - - - 0 0
226 enet 100226 1500 - - - - - 0 0
255 enet 100255 1500 - - - - - 0 0
280 enet 100280 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - srb 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
05-04-2014 04:20 PM
on the 3350, can you try this
config t
vlan database
vlan 184 name testvlan
exit
and test from PC again?
05-04-2014 04:33 PM
Hi.
VLAN database command not working. I am seeing below.
3550(config)#vlan database
Command rejected: Bad VLAN list - character #1 is a non-numeric
character ('d').
3550(config)#vlan ?
WORD ISL VLAN IDs 1-4094
access-map Create vlan access-map or enter vlan access-map command mode
dot1q dot1q parameters
filter Apply a VLAN Map
internal internal VLAN
05-05-2014 03:19 AM
hi,
Can you post "show ip int brief" on both 3550 & 2960?
05-05-2014 07:23 AM
The show interface trunk command on the third post verifies that VLAN 184 is created and is in forwarding mode. This is not an issue of the VLAN being defined at the switch level.
I think we need to turn our troubleshooting up to the core level. Go to the switch where you have defined the default gateway for VLAN 184. Is VLAN 184 actively working for any other portion of your network? I could be wrong, but it looks as if VLAN 184 isn't properly defined on this switch. Assuming this is the issue, consider the following:
1. Is the SVI for VLAN 184 created and in the up/up state?
2. Do you have a DCHP scope configured?
3. Do you have a network statement in your routing protocol defined?
05-10-2014 03:04 AM
Hi Procopius..
Yes. vlan 184 is up and working. we have another L2 switches configured on vlan 184 & they are working,also DHCP scope is configured.
One more thing i want to ask you. Do i need to have network statement on my L3 switch(IP routing enabled) to make communication between VLANs(SVI) or only configuring trunk is capable of doing same?
05-12-2014 10:29 AM
No routing protocol needed for inter-vlan routing when both SVIs are configured on the same switch. You just need ip routing enabled. You will need a network statement to communicate to networks beyond that core switch.
I have attached a drawing of your network based upon your description. Can you please confirm this is correct? If yes, then I am a little perplexed as to the problem. Question: Can other VLANs pass traffic on this new 3550?
Another idea would be to create an SVI for VLAN 184 on your new 3550. See if you can ping the VLAN 184 default gateway from your 3550.
