3550XL VoIP configuration
hi
im using a 3550XL with c3500xl-c3h2s-mz.120-5.WC17.bin IOS version and i tried the standard configurion
switcport mode access
switchport access vlan 20
switchport voice vlan 10
and although it accept the voice vlan , it does nt work . all ports belong only in data vlan .
is there any way to change this?
thanks
1 ACCEPTED SOLUTION
Re: 3550XL VoIP configuration
Unfortunately the 3500XL (& 2900XL) run IOS 12.0 and must be configured differently from the current range of switches (2950 and up) with regards to Voice VLANs. To enable Voice VLANs like you would on access ports on a 2950 or later you must configure the ports on the 3500XL & 2900XL as trunks. QoS is also not configurable on this platform - the 3524XL-PWR and 3548XL support QoS but it cannot be configured, all other 2900XL & 3500XL don't support QoS.
!!!!!2950 or later typical config
interface FastEthernet0/1
switchport mode access
switchport access vlan 10
switchport voice vlan 100
!!!!!3500XL/2900XL Voice VLAN Access port
switchport mode trunk
switchport trunk native vlan 10
switchport trunk allowed vlan 1,10,100,1002-1005
In both examples above the Access VLAN is 10 and the Voice (Tagged) VLAN is 100, note the configuration differences on the XL series to achieve the same functionality.
The 3548XL has been EOS since July 2002, and was EOL July 2007. The recommended replacement products are now also EOS (2950 & 3550) so you should really look at replacing these with 3560/3750 series switches.
Andy
HI, [Pls Rate if HELPS]
Refer Link below on HOWTO Configure Voice VLAN:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_13_ea1/configuration/guide/swvoip.html#wp1034062
Pls Rate if HELPS
Best Regards,
Guru Prasad R
hi
i have already read that pdf and many other but the model i use ( cisco WS-C3548-XL) doesnt support mls qos command or voice vlan without trunking the ports... i can see only switchport priority ....command for QoS.
is it the IOS version or the device ?
Andy
871
