08-11-2009 06:10 AM - edited 03-06-2019 07:11 AM
I received a 3560 replacement switch without an IOS. I have the IOS for the switch on hand. What would be best practice to load a new IOS on a 3560 switch?
Solved! Go to Solution.
08-11-2009 06:18 AM
Look for Document 41845..."Recovering Catalyst Fixed Configuration Switches from a Corrupted or Missing Image"
I have attached the document.
Mike
08-11-2009 06:19 AM
Hi Jaime,
Does your switch goes straight into the ROMMON? You can use XMODEM to load the IOS into the flash, but this process is extreme time consuming.
HTH,
jerry
08-11-2009 06:18 AM
08-11-2009 06:19 AM
Hi Jaime,
HTH,
jerry
