3560 PoE problem
Rafael Mendes
Level 2
Level 2
Hello Everyone,
I have a 3560 switch 48-PS, and i need plug two IP phones 7911.
But do not get the power in the ports, and the phones do not start.
Show power inline command:
Available:370.0(w)  Used:85.9(w)  Remaining:284.1(w)
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi0/1     auto   off        0.0     n/a                 n/a   15.4
Gi0/2     auto   off        0.0     n/a                 n/a   15.4
Gi0/3     auto   off        0.0     n/a                 n/a   15.4
Gi0/4     auto   off        0.0     n/a                 n/a   15.4
Gi0/5     auto   off        0.0     n/a                 n/a   15.4
Gi0/6     auto   off        0.0     n/a                 n/a   15.4
Gi0/7     auto   off        0.0     n/a                 n/a   15.4
Gi0/8     auto   off        0.0     n/a                 n/a   15.4
Gi0/9     auto   off        0.0     n/a                 n/a   15.4
Gi0/10    auto   off        0.0     n/a                 n/a   15.4
Gi0/11    auto   off        0.0     n/a                 n/a   15.4
Gi0/12    auto   off        0.0     n/a                 n/a   15.4
Gi0/13    auto   off        0.0     n/a                 n/a   15.4
Gi0/14    auto   off        0.0     n/a                 n/a   15.4
Gi0/15    auto   off        0.0     n/a                 n/a   15.4
Gi0/16    auto   off        0.0     n/a                 n/a   15.4
Gi0/17    auto   off        0.0     n/a                 n/a   15.4
Gi0/18    auto   off        0.0     n/a                 n/a   15.4
Gi0/19    auto   off        0.0     n/a                 n/a   15.4
                            (Watts)
Gi0/20    auto   off        0.0     n/a                 n/a   15.4
Gi0/21    auto   off        0.0     n/a                 n/a   15.4
Gi0/22    auto   off        0.0     n/a                 n/a   15.4
Gi0/23    auto   off        0.0     n/a                 n/a   15.4
Gi0/24    auto   off        0.0     n/a                 n/a   15.4
Gi0/25    auto   off        0.0     n/a                 n/a   15.4
Gi0/26    auto   off        0.0     n/a                 n/a   15.4
Gi0/27    auto   off        0.0     n/a                 n/a   15.4
Gi0/28    auto   off        0.0     n/a                 n/a   15.4
Gi0/29    auto   off        0.0     n/a                 n/a   15.4
Gi0/30    auto   off        0.0     n/a                 n/a   15.4
Gi0/31    auto   off        0.0     n/a                 n/a   15.4
Gi0/32    auto   off        0.0     n/a                 n/a   15.4
Gi0/33    auto   off        0.0     n/a                 n/a   15.4
Gi0/34    auto   on         6.3     IP Phone 7960       n/a   15.4
Gi0/35    auto   off        0.0     n/a                 n/a   15.4
Gi0/36    auto   off        0.0     n/a                 n/a   15.4
Gi0/37    auto   off        0.0     n/a                 n/a   15.4
Gi0/38    auto   off        0.0     n/a                 n/a   15.4
Gi0/39    auto   off        0.0     n/a                 n/a   15.4
Gi0/40    auto   off        0.0     n/a                 n/a   15.4
Gi0/41    auto   off        0.0     n/a                 n/a   15.4
                            (Watts)
Gi0/42    auto   on         12.2    AIR-LAP1131AG-T-K9  n/a   15.4
Gi0/43    auto   off        0.0     n/a                 n/a   15.4
Gi0/44    auto   on         12.2    AIR-LAP1131AG-T-K9  n/a   15.4
Gi0/45    auto   on         12.2    AIR-LAP1131AG-T-K9  n/a   15.4
Gi0/46    auto   on         12.2    AIR-LAP1131AG-T-K9  n/a   15.4
Gi0/47    auto   on         15.4    Ieee PD             3     15.4
Gi0/48    auto   on         15.4    Ieee PD             3     15.4
Can I be having a problem of variation in the grid?
How to check this for commands on the switches?
Tks a lot.
Rafael Mendes
9 Replies 9
Jon Marshall
Rafael
You may get a better response if you post into the VOIP forums. However can you check that you have this under the interfaces -
int gi0/1
power inline auto
Jon
Hi Jon,
Tks for response.
Well, the problem occurs in all PoE ports, and all kind of equipments. For example (Ip Phones, AP's, etc).
In all other switches configured in the network, i don't need include this command "power inline auto".
Is there any command to check grid "power domain" and fan?
Tks.
Is CDP enabled on the ports?  Can you post the interface config for the ports having a problem and compare them with ports that are working?
Yes, CDP is enabled.
All ports have the same configuration(working and not working):
interface GigabitEthernet0/5
switchport mode access
switchport voice vlan X
dot1x mac-auth-bypass eap
dot1x pae authenticator
dot1x port-control auto
dot1x violation-mode protect
dot1x timeout tx-period X
spanning-tree portfast
I  still have the impression that there is a problem in the electrical  network, most do not know verify this with the switch command line.
Anyone can help me?
Tks
Sure, you can test for TDR.  (NOTE:  TDR is not supported in all 3560/3750 switches.)
The commands are:
1.  "test cable tdr interface ";
2.  Wait for about 10-15 seconds;
3.  "sh cable  cable tdr interface "
The command, depending on IOS version, should not be disruptive.  Post the output if you have any doubts.
Not working POE port
Interface Speed Local pair Pair length        Remote pair Pair status
Gi0/25    1000M Pair A     27   +/- 4  meters Pair A      Normal
                Pair B     28   +/- 4  meters Pair B      Normal
                Pair C     28   +/- 4  meters Pair C      Normal
                Pair D     27   +/- 4  meters Pair D      Normal
Working POE port
Gi0/29    1000M Pair A     19   +/- 4  meters Pair A      Normal
                Pair B     19   +/- 4  meters Pair B      Normal
                Pair C     16   +/- 4  meters Pair C      Normal
                Pair D     20   +/- 4  meters Pair D      Normal
I am also having same issues in some port or some times
Any help or Bug in the IOS version
C3560 Software (C3560-IPBASE-M), Version 12.2(50)SE1,
thanks
This is not the same as the beginning of this thread.
Can you please post the result of the "sh power inline" please?  What are you trying to power up?
Available:370.0(w)  Used:207.4(w)  Remaining:162.6(w)
                            (Watts)
Gi0/1     auto   on         15.4    AIR-LAP1252AG-E-K9  3     15.4
Gi0/4     auto   on         12.0    IP Phone 7945       3     15.4
Gi0/8     auto   on         12.0    IP Phone 7945       3     15.4
Gi0/12    auto   on         12.0    IP Phone 7945       3     15.4
Gi0/13    auto   on         12.0    IP Phone 7945       3     15.4
Gi0/15    auto   on         12.0    IP Phone 7945       3     15.4
Gi0/17    auto   on         12.0    IP Phone 7945       3     15.4
Gi0/20    auto   on         12.0    IP Phone 7945       3     15.4
                            (Watts)
Gi0/21    auto   on         12.0    IP Phone 7945       3     15.4
Gi0/24    auto   on         12.0    IP Phone 7945       3     15.4
Gi0/29    auto   on         12.0    IP Phone 7965       3     15.4
Gi0/34    auto   on         12.0    IP Phone 7945       3     15.4
Gi0/42    auto   on         12.0    IP Phone 7945       3     15.4
Gi0/43    auto   on         12.0    IP Phone 7945       3     15.4
                            (Watts)
Gi0/44    auto   on         12.0    IP Phone 7945       3     15.4
Gi0/45    auto   on         12.0    IP Phone 7965       3     15.4
Gi0/46    auto   on         12.0    IP Phone 7945       3     15.4
Gi0/47    auto   off        0.0     n/a                 n/a   15.4
Gi0/48    auto   off        0.0     n/a                 n/a   15.4
all the ports are same confgiuration some things power is coming up after rebooting like that another one
all CP79XX IP phone means 12.0 watts
