3560 Port channel
I have the core stack using 7 3750 switches with multiple port channels setup, and we have remote locations with 3560 switches all using port channels. I need the commands to see all port channels setup on the 3750 along with the 3560 switches. I need some help or step-by-step information on how to setup a new port channel for another 3560 switch I'm adding to the network.
P/S is there a document for port-channel configuration also.
Thank you
  • LAN Switching and Routing
1 ACCEPTED SOLUTION
Purple
Re: 3560 Port channel
For full detail use "show etherchannel detail". For a less busy output use "show ether summ" . For a new channel between cisco devices do the following as an example.
conf t
int port-channel 25
shut
For the ports in the channel.
interface range g1/0/X , g1/0/X
channel-group 25 mode desirable non-silent
After this then do a "no shut on the port channel interface on each end to bring up the channel.
Super Bronze
You might want to start with the configuration guide chapter that addresses port channels. E.g. http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_50_se/configuration/guide/swethchl.html
Please can you give me the commands to see what port channels I have and how to add another.
Purple
conf t
int port-channel 25
shut
762
