03-24-2014 08:52 AM - edited 03-07-2019 06:50 PM
Having trouble configuring a new switch.Switch B port 48 is connecting to switch A port 37.
Don't know what i have done wrong.
Attached are the running config from both switchs.
Thanks for the help.
11-19-2014 03:29 AM
Can you tell us a little about the problem that you're having?
11-19-2014 03:33 AM
My dear let us begin from scratch.
why do you have below settings on switch A on port 37
switchport trunk allowed vlan 1,5,10,25,100 switchport mode access
let us do simple things first. ( make port setting of switch A prot 37 and switch B port 48 as default ).
and then simply trunk and check.
if all works well, and use vlan allow command on it.
hope this helps.
