3560 switch don't have interfaces in show run
Hi All,
I have 3560 switch and when i do show run it doesn't show me any interfaces.
it is the first time to configure it .
i don't know what to do as i can't replace it and i'm indeed need to use it.
can anyone help in this.
Thanks in advance,
Ayman Yehia
2 ACCEPTED SOLUTIONS
Re: 3560 switch don't have interfaces in show run
hi jorge,
Kindly find the attached file of logs after reloading the switch.
their is error in POST: PortASIC CAM Subsystem Tests : Begin
TCAM (asic:0, bit: 0) data bus test failed
Best Regards,
Ayman Yehia
Ayman,
I suppose this is an hardware failure of TCAM data bus you need to replace the switch being a fixed configuration switch.if you have a valid service contract you can open an RMA to have the switch replaced.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Bronze
The switch ASICs that control the communication between  the Ethernet ports and switch data bus are broken.
The switch should be replaced.
Regards.
it gives me this message:
!!! WARNING: The switch is not usable !!!
Hi All,
Thanks in advance,
Ayman Yehia
Ayman,
What exactly is your requirement to configure in this switch,just want to configure interface or vlan or any other configuration.Is this switch is in default configuration state or having some configuration in it already.
If you want to configure a SVI for some vlan you can configuure by entering into configure mode-
configure#vlan 10
configure#int vlan 10
configure-interface#ip addr 1.1.x.x 255.255.x.x
Hope to Help !!
Ganesh.H
hi ganeshh,
i can't configure any ports for this switch as i can't type the following:
(config)# interface fastethernet0/1 to 0/24
or add new vlan to the switch ,it gives me the following message:
Switch(config)#vlan 200
Insuffient core memory to allocate to new VLAN 200.
Switch(config-vlan)#^Z
%Error exiting config-vlan mode 33: Bad VLAN count
Switch#
Ayman Yehia
Bronze
That message may indicate some hardware on the switch has a failure. Please reload the switch while connected via console to it and check for any failed POST message. More specifically "Ethernet-Controller x failed POST" that would explain why you cannot see any Ethernet interface.
Regards.
hi jorge,
Best Regards,
Ayman Yehia
hi jorge,
Best Regards,
Ayman Yehia
Ayman,
Hope to Help !!
Ganesh.H
Bronze
Regards.
thanks for your help ganeshh and jorge
i'll try to replace it
thanks for your replies
Ayman Yehia
1350
