01-09-2014 01:23 AM - edited 03-07-2019 05:27 PM
Hi Guys,
Logs seen on switch:
FLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:26:37: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:27:06: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 252 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:28:06: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:28:37: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/25 and port Gi0/26
Jan 7 17:29:10: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:31:50: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:32:26: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/25 and port Gi0/26
Jan 7 17:32:39: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:33:28: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/25 and port Gi0/26
Jan 7 17:34:34: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/25 and port Gi0/26
Jan 7 17:35:38: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/25 and port Gi0/26
Jan 7 17:36:35: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:37:39: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:38:06: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:38:38: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/25 and port Gi0/26
Jan 7 17:39:00: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:40:40: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:41:15: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:41:38: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/25 and port Gi0/26
Jan 7 17:42:45: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/25 and port Gi0/26
Jan 7 17:43:27: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:43:40: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:43:59: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:46:01: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:46:57: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:47:29: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/5, changed state to down
Jan 7 17:47:30: %LINK-3-UPDOWN: Interface GigabitEthernet0/5, changed state to down
Jan 7 17:48:03: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:48:44: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/25 and port Gi0/26
Jan 7 17:49:02: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:49:46: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:50:14: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Jan 7 17:50:49: %SW_MATM-4-MACFLAP_NOTIF: Host 707b.e8b9.5a36 in vlan 250 is flapping between port Gi0/26 and port Gi0/25
Switch Configuration:
interface GigabitEthernet0/25
switchport trunk allowed vlan 250-252
switchport mode trunk
speed nonegotiate
interface GigabitEthernet0/26
speed nonegotiate
I believe that NE40(huawei router) is configured with VRRP and Layer 3 Port Channel,
so I tried to configure port channel(but only Layer 2..because of not capable of sub interface port chan/ needed because we have VLANS with IPs) for Gi0/25 & Gi0/26... the flapping is gone but some error appeared in NE40 router.See below.
Jan 3 2014 15:36:26+08:00 CNR-CS-RTR-002 %%01VRRP/4/STATEWARNINGEXTEND(l)[0]:Virtual Router state MASTER changed to BACKUP, because of priority calculation. (Interface=Eth-Trunk11.250, VrId=7, InetType=IPV4)
Jan 3 2014 15:36:26+08:00 CNR-CS-RTR-002 %%01VRRP/4/STATEWARNINGEXTEND(l)[1]:Virtual Router state BACKUP changed to MASTER, because of protocol timer expired. (Interface=Eth-Trunk11.250, VrId=7, InetType=IPV4)
Jan 3 2014 15:36:25+08:00 CNR-CS-RTR-002 %%01VRRP/4/STATEWARNINGEXTEND(l)[2]:Virtual Router state MASTER changed to BACKUP, because of priority calculation. (Interface=Eth-Trunk11.251, VrId=8, InetType=IPV4)
Jan 3 2014 15:36:25+08:00 CNR-CS-RTR-002 %%01VRRP/4/STATEWARNINGEXTEND(l)[3]:Virtual Router state BACKUP changed to MASTER, because of protocol timer expired. (Interface=Eth-Trunk11.251, VrId=8, InetType=IPV4)
Jan 3 2014 15:35:24+08:00 CNR-CS-RTR-002 %%01VRRP/4/STATEWARNINGEXTEND(l)[4]:Virtual Router state MASTER changed to BACKUP, because of priority calculation. (Interface=Eth-Trunk11.252, VrId=9, InetType=IPV4)
FYI. Ne40 is a third party device.
Is it not possible to have Layer 2 and layer 3 portchannel connectivity? if not, based on above info what do you recommend?
Can you please help me guys. Thanks
01-09-2014 01:30 AM
I'd by asking you WHY are the two ports not in an etherchannel.
01-09-2014 01:50 AM
The switch is not capable of port channel subinterface, they want that I think because of routing config in router side(huawei NE40 that they needed to route in specific port channel sub interface).
What do you thing my friend?
01-09-2014 01:52 AM
Who said that? All Cisco switches are capable of port channel.
01-09-2014 01:59 AM
Yes I can do port channel, I mean the command for example
config t
int port-channel 11.250
is not working
See below Thread https://supportforums.cisco.com/thread/2070565
01-09-2014 02:02 AM
Errrr ... You are doing SUB-INTERFACE on a portchannel. Why not do portchannel?
01-09-2014 02:19 AM
When I do portchannel, VRRP error in router stated to appear . See below.
The router Guys said that they configured it with L3 portchannel
01-09-2014 02:24 AM
This could be why, a Layer 3 port channel needs an IP address in the same subnet as the Router end.
You were/are using a L2 Trunk port.
Is the router acting as the default gateway for any of your Vlans?
If so, a Layer 3 port channel will create an issue for you.
If not, create a L3 port channel and set the Cisco switch to have a default route pointing to the router as its next hop.
01-09-2014 02:25 AM
Layer 3 etherchannel. Right.
Go here: Configuring Layer 3 EtherChannels
01-09-2014 02:34 AM
They are using subinterface portchannel. Can you verify their confgi ? See NE40 config below
01-09-2014 02:37 AM
I can't comment on Huawei because I have never used one.
Can you try to get the Huawei router to do just Layer 2 etherchannel and observe?
01-09-2014 02:00 AM
The switch is recieving frames with the same source MAC address from both trunk links.
Think about the switches CAM table, it needs an entry for MAC Address 1111.2222.3333 so it knows which port to forward frames out of destined for this address. Currently it is seeing frames from ports 25 and 26 with this source MAC so what does it add to its CAM table??
This would be fine if they were part of a port channel but not when they are standard L2 trunks.
There is a misconfiguration somewhere. Can you advise on the config on the router side??
01-09-2014 02:23 AM
See below for Huawei router config
interface Eth-Trunk11
description For ITP Link
mode lacp-static
interface Eth-Trunk11.250
vlan-type dot1q 250
description For ITP Signaling
shutdown
ip binding vpn-instance SIGTRAN
ip address
vrrp vrid 7 virtual-ip
vrrp vrid 7 priority 140
statistic enable
interface Eth-Trunk11.251
vlan-type dot1q 251
description For ITP Application
shutdown
ip binding vpn-instance BE
ip address
vrrp vrid 8 virtual-ip
vrrp vrid 8 priority 140
statistic enable
interface Eth-Trunk11.252
vlan-type dot1q 252
description For ITP OM
shutdown
ip binding vpn-instance OM
ip address
vrrp vrid 9 virtual-ip
vrrp vrid 9 priority 140
statistic enable
interface GigabitEthernet5/1/4
description To ITP L3 Switch2
undo shutdown
eth-trunk 11
interface GigabitEthernet5/1/5
undo shutdown
eth-trunk 11
01-09-2014 02:53 AM
mode lacp-static
As this is not a Cisco Router, they are using LACP for thier port-channel. I know nothing about Huawei but I suspect you need to create a L3 LACP Port channel
#interface Po1
no switchport
#ip address
#interface GigabitEthernet0/25
#no swichport
#no ip address
#channel-group 1 mode active
#interface GigabitEthernet0/26
#no swichport
#no ip address
01-09-2014 05:50 PM
As per IP core, that's their standard //to have layer 3 portchannel-subinterface
BTW thanks guys
