3560 Switch not booting up
My switch is not booting up, when I power it on the fans rev up then go down after about 1 second.
LEDs remain the same from power up:
System = OFF
RPS = OFF
Stat = Orange/Amber
Duplex = Orange/Amber
Speed = Yellow
PoE = Yellow
Nothing being transmitted out of console either.
What could be the problem... is this switch toast?
Thanks for looking
back to school!!
2 ACCEPTED SOLUTIONS
Re: 3560 Switch not booting up
Only with a current smart net contract with Cisco.
This switch went end of life and no new contracts for support will be provided if it is one of these listed here
http://www.cisco.com/en/US/products/hw/switches/ps5528/prod_eol_notices_list.html
james,
No you cant do that. You need to buyor have the valic cisco contract associated with this hardware to have this RMA from cisco.
Inayath
Purple
  Sounds like it if you are getting nothing from the console and you know your cable works on other cisco gear. RMA time.
This was bought from ebay so I dont think RMA is an option. I have had a refund from ebay for the item however thought I would check on here before it gets thrown in the bin.
If this is toast are there any parts inside worth keeping?
CCENT
back to school!!
Anyone else have any other thoughts? Can these things be serviced?
back to school!!
I had the same thing happen to a switch in production.
Nothing much you can do except use it as a monitor stand.......
Get the switch RMA.
Can I RMA this switch even though it is second hand from ebay?
CCENT
back to school!!
james,
Inayath
Just like to say Thank-you all for replying and I have decided to open up the switch and just have a noisy round inside. Not going to try and fix it, just be familiar of it components.
Thanks again
James
CCENT
back to school!!
539
