Webcast-Catalyst9k
3560 switch support with BGP and OSPF
Dear All,
Please tell me which image i need to have for the support of BGP and OSPF. I have now
c3560-ipbase-mz.122-25.SEE2.bin. Even i tried c3560-advipservicesk9-mz.122-35.SE1.bin.
But this image also not supported the bgp and ospf.
switch(config)#router bgp 10
switch(config)#Protocol not in this image
Which image needs to upload for the bgp and ospf support.
Switch is 3560-48-PS-S
swamy
Silver
Re: 3560 switch support with BGP and OSPF
According to the FAQ http://www.cisco.com/en/US/products/hw/switches/ps5528/products_qanda_item09186a00801f3d71.shtml
The ipservices image itself would support your features. Advanced ip services should do it.
Have you enabled "ip routing" command on your switch before starting your configuration?
Hoogen
Hoogen,
i works fine
swamy
Swamy,
You need an IP services image to support BGP and OSPF. The switch you have is with the Standard image i.e Ip base image. You need an enhanced image i.e Ip services.
HTH,Please rate if it does.
-amit singh
Do we require a SAL to
Do we require a SAL to utilise advanced routing features?
Brendan
9823
