Webcast-Catalyst9k
Highlighted
3560 v2 install at remote site
I have a remote site that's just installed a Cataylst 3560 v2 which I need to configure. I'm guessing the default username and password are both cisco; however, web GUI and Configuration Assistant won't let me in - both are asking for realm level_15_access. Is there another username/passwrod? I've tried SSH, too. What's the best way I can set this up remotely?
Everyone's tags (1)
VIP Super Bronze
I have never used the GUI before, but if you are trying to Telnet or SSH, you need to configure the vty lines before you can access them.  This is assuming you already have an IP address on the switch and it is reachable.
here is an example of vty lines configs for telnet
line vty 0 4
login local
transport input telnet
line vty 5 15
login local
username test password test123
username test privi 15
or this could be any other username you have on the device.
If you don't have these config, you would need to send some one to console to it.
This switch doesn't come with a console cable and there's not another one there. The siwtch is suppsoed to have Express Setup, which I've used before. It did get a DHCP address from the network and not responding at 10.0.0.1.
157
