Community Member
3560 vlans
HI,
I have 3560G L3 switch i configured 6 VLN's in this switch i have given different ip subnetmasks for vlans  but vlans not able access internet.
i am using host gatway of vlan ip addres.
Everyone's tags (5)
3560 vlans
Can you post the config and explain how the internet is connected to your network.
3560 vlans
Hi Narsimha,
What do you mean exactly "i am using host gatway of vlan ip addres"
Do you have any access-lists applied under those vlan interfaces?
And make sure you have default route 0.0.0.0 0.0.0.0 WAN_Router IP.
Please rate the helpfull posts.
Naidu.
Community Member
3560 vlans
hi,
if you dont use a dynamic routing protocol, make sure you enter static routes on your gateway for each vlan you want to give internet access.
florian
270
