3560-X LAN Base - No Static IP routing available
I purchased WS-C3560X-24T-L which comes with LAN Base IOS license set however I cannot configure static routing on it. In data sheets under High-Performance IP Routing section it clearly states that you can confiugure up to 16 static routes with LAN Base option.
Anybody had a similar problem to give me any clues how to configure static routing on 3560-X with Lan Base?
Thanks in advance.
Remi
1 ACCEPTED SOLUTION
Silver
According to the configuration guide:http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_58_se/configuration/guide/swiprout.html#wp1118518
Starting with Cisco IOS Release 12.2(58)SE, switches running the LAN base image support 16 user-configured static routes on SVIs. Static routing configuration is supported on the LAN base image only with the default SDM template and only on SVI interfaces. No routing protocols are supported.
Hope this helps..!
Silver
Hope this helps..!
Hi Leo,
Indeed it helps! I had 12.2(55)SE image and after the upgrade I could configure the static routing.
Thanks a lot for your findings.
Best regards,
Remi
575
