Webcast-Catalyst9k
3560G-48PS gig port question
How many gig connections can a 3560G-48PS with redundant gig fiber uplinks support before you see performance and/or connection issues?
thanks.
Everyone's tags (1)
1 REPLY
Re: 3560G-48PS gig port question
That will off course depend on the traffic from the gig ports. If you have 48 ports using 10% load, you'll need 4,8 gig uplinks, so 5 gig uplinks. I would advise to start of with your best estimate based on your user profiles. Then monitor the uplink and adjust when needed.
167
