Community Member
3560G restricting access to websites
I am curious if you can restrict access to websites via a 3560 switch? What I have in mind is to setup rules that will prevent and workstation IP from accessing certain sites via a port.
Community Member
Re: 3560G restricting access to websites
Hi, Read your post and yes you can filter website with an ACL or access control list, you can deny your user from accessing the website IP address or you can deny the website IP access to your users.
"access-list 101 deny tcp source IP xxx.xxx.xxx.xxx destination IP xxx.xxx.xxx.xxx eq www"
You can use the any source IP command to block all host on your network. check out some links on ACL and filtering websites. HTH
http://www.cisco.com/en/US/tech/tk648/tk361/tk821/tsd_technology_support_sub-protocol_home.html
Community Member
Excellent
Thank you
110
