3560x ios upgrade
adarabeaa
Dears,
can I upgrade the switch ios from lan base to ip base without buy a new license ?
BR,
Abdallah.
yes, you can buy the IPBase feature-set upgrade. These are the part':
3560-X LAN Base to IP Base Upgrade License
C3560X-24-L-S
C3560X-24 LAN Base to IP Base Paper License
C3560X-48-L-S
C3560X-48 LAN Base to IP Base Paper License
L-C3560X-24-L-S
C3560X-24 LAN Base to IP Base E-License
L-C3560X-48-L-S
C3560X-48 LAN Base to IP Base E-License
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Permanently?  No?  You need to buy a license and they appy it to the device.  Karsten's post has the part numbers.
Temporarily?  Yes.  There's a way to generate a temp license, so you can use additional features, while you're working to acquire your permanent license.  Temporary license will only work for a limited time.  (NB: you'll also need to run the universal image.)
adarabeaa
many thanks all
