3560x won't boot
Islam Sallaj
All,
I unpacked a new 3560x and went to put our standard code version on it c3560e-ipbasek9-mz.122-53.SE2.  Everything seemed to upgraded fine but it won't boot to a console prompt.  It seems like it loads the IOS image fine but can't get passed the
Front-end Microcode IMG MGR: Programming device 0.
Here is a snap shot of the console log as it boots...any thoughts?
izzy
Using driver version 1 for media type 2
Base ethernet MAC Address: a4:4c:11:58:25:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
mifs[2]: 12 files, 1 directories
mifs[2]: Total bytes     :    2097152
mifs[2]: Bytes used      :     755200
mifs[2]: Bytes available :    1341952
mifs[2]: mifs fsck took 2 seconds.
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes     :    4194304
mifs[3]: Bytes used      :       1024
mifs[3]: Bytes available :    4193280
mifs[3]: mifs fsck took 3 seconds.
mifs[4]: 5 files, 1 directories
mifs[4]: Total bytes     :     524288
mifs[4]: Bytes used      :       9216
mifs[4]: Bytes available :     515072
mifs[4]: mifs fsck took 0 seconds.
mifs[5]: 5 files, 1 directories
mifs[5]: Total bytes     :     524288
mifs[5]: Bytes used      :       9216
mifs[5]: Bytes available :     515072
mifs[5]: mifs fsck took 1 seconds.
mifs[6]: 437 files, 9 directories
mifs[6]: Total bytes     :   57671680
mifs[6]: Bytes used      :   18752512
mifs[6]: Bytes available :   38919168
mifs[6]: mifs fsck took 43 seconds.
...done Initializing Flash.
done.
Loading "flash:/c3560e-ipbasek9-mz.122-53.SE2/c3560e-ipbasek9-mz.122-53.SE2.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:/c3560e-ipbasek9-mz.122-53.SE2/c3560e-ipbasek9-mz.122-53.SE2.bin" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C3560E Software (C3560E-IPBASEK9-M), Version 12.2(53)SE2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 21-Apr-10 04:26 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02400000
Initializing flashfs...
mifs[3]: 12 files, 1 directories
mifs[3]: Total bytes     : 2097152
mifs[3]: Bytes used      : 755200
mifs[3]: Bytes available : 1341952
mifs[3]: mifs fsck took 0 seconds.
mifs[3]: Initialization complete.
mifs[4]: 0 files, 1 directories
mifs[4]: Total bytes     : 4194304
mifs[4]: Bytes used      : 1024
mifs[4]: Bytes available : 4193280
mifs[4]: Initialization complete.
mifs[5]: Initialization complete.
mifs[6]: 5 files, 1 directories
mifs[6]: Total bytes     : 524288
mifs[6]: Bytes used      : 9216
mifs[6]: Bytes available : 515072
mifs[6]: mifs fsck took 0 seconds.
mifs[6]: Initialization complete.
mifs[7]: 437 files, 9 directories
mifs[7]: Total bytes     : 57671680
mifs[7]: Bytes used      : 18752512
mifs[7]: Bytes available : 38919168
mifs[7]: mifs fsck took 1 seconds.
mifs[7]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade.. not needed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: SF ASIC BIST : Begin
POST: SF ASIC BIST : End, Status Passed
POST: Switch Fabric Memory Tests : Begin
POST: Switch Fabric Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
front_end/ (directory)
extracting front_end/fe_type_4 (78400 bytes)
extracting front_end/fe_type_3 (78400 bytes)
extracting front_end/fe_type_2 (78400 bytes)
extracting front_end/fe_type_5_0 (594412 bytes)
extracting front_end/fe_type_5_1 (276894 bytes)
extracting front_end/fe_type_5_2 (25142 bytes)
extracting front_end/fe_type_5_3 (85402 bytes)
extracting front_end/app_data.srec (25142 bytes)
extracting front_end/front_end_ucode_info (309 bytes)
extracting ucode_info (77 bytes)
% Info: subordinate ucode is already extracted.
Front-end Microcode IMG MGR: found microcode images for 4 devices.
Image for front-end 0: flash:/front_end_ucode_cache/ucode.3
Image for front-end 0: flash:/front_end_ucode_cache/ucode.4
Image for front-end 0: flash:/front_end_ucode_cache/ucode.5
Image for front-end 0: flash:/front_end_ucode_cache/ucode.6
Front-end Microcode IMG MGR: Preparing to program device microcode...
Front-end Microcode IMG MGR: Preparing to program device[0]...594412 bytes.
Front-end Microcode IMG MGR: Programming device 0...rrrrrrwssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssss
spssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssss
ssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssss
ssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssss
ssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspss
ssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssss
ssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssss
ssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspsssssssssssssssssssp
ssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssss
ssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssss
ssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssssspssssssssssssssssss
spssssss
Ivan Shirshin
Hi Islam,
The switches have a small MCU(MicroController Unit) to offload processing of some of the hardware interfaces like POE , Fan, power supply etc. The MCU runs a microcode that is different from the main processor where IOS runs. Normally, this microcode  doesn't need to be upgraded with regular IOS (i.e., newer versions of IOS can work with older versions of microcode). It may be upgraded if there are new bugs/feature enhancements that require the microcode to be changed.
Programming front end microcode should only happen once when upgrading to a higher version with newer microcode.
The thing is that this MCU programming takes awhile, especially on first boot. I see you did not get this finished, no any errors were produced, so I suggest to put a switch aside and wait till it does the programming. In case you see some errors after that, do let me know.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
8 Replies 8
Ivan Shirshin
Hi Islam,
Kind Regards,
Ivan
Kind Regards,
Ivan
Ivan,
You were spot on...took a while but the switch is up and operational...
Many thanks
izzy
would love to grade your post....how?
Hi Islam,
Glad everything is fine :-) You can rate the posts by selecting the number of the stars (from 1 to 5) under the post (and thanks for rating!).
Kind Regards,
Ivan
Kind Regards,
Ivan
Hi Ivan,
You are a life saver!!!!!...
Thanks a lot.
Aminu
Welcome, Aminu
Kind Regards,
Ivan
Kind Regards,
Ivan
thank you Ivan. You safe my life
veevekraj
Thanks Ivan Shirshin. I am speechless about your answer.Great Man.
