Community Member
3640 router loses configuration
Every time I save a configuration with "write memory" or "copy running-config startup-config" the router doesn't keep its settings when I turn it off. When it comes back on it just asks me if I want to enter initial setup. Then I have to manually copy the startup-config into the running config. What's wrong?
Re: 3640 router loses configuration
check config-register
sh ver
should be 0x2102
conf t
config-register 0x2102
end
wr
reload
Check if the config-register is 0x2142. If so, it will skip the startup config while booting. Change the same to "config-register 0x2102"
HTH,
Nagendra
Community Member
Thanks guys. That did the trick.
110
