3640 router upgrade.
Folks,
I was tring to upgrade the IOS of one of my 3640 routers and in the process I was notified of lack of enough memory.I had to accept to erase the flash before the upgrade but before that could finish, I had one of my colleagues stepping on the power cable thereby putting the router off. Now when I connect to the router,it takes me to the rommon> mode i guess because it cannot find the IOS to load.
Could someone please show me how I can get the IOS loaded so I can boot into the router.
Hall of Fame Super Blue
Re: 3640 router upgrade.
If you are really sure you have erased your current image you can use xmodem to copy an IOS onto the router but it's not quick, ie. probably want to set it off before you go home.
Attached is a link to using xmodem for a 3600 router.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml#proc_3600
Jon
Super Bronze
If you have an external flash card that you could place in another router, you could preload the IOS on it.
106
