Webcast-Catalyst9k
3745 and 2620 BGP support
Will 3745 and 2620 XM router support full BGP routes.
Re: 3745 and 2620 BGP support
Yes, they both do.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Silver
To be more specific, you can accept full BGP routes from a single EBGP peer and a single IBGP peer IF you have 256 MB of SDRAM in the router and you run the correct IOS and feature set.
The c3745 is easy as has accepted 256 MB from inception, the c2620XM will most likely require a ROM and SDRAM upgrade.
The IOS version needs to be the MINIMUM required to run BGP. I.e., don't run IP plus (which includes voice, etc.) or Enterprise anything. Since 12.4(4)T, Advanced Security has supported BGP4. I have had great luck with that feature set on 12.4(4)T or higher on both platforms you mention. For example:
http://www.cisco.com/cgi-bin/Software/Iosplanner/Planner-tool/iosplanner.cgi?get_crypto=&data_from=&hardware_name=3745&software_name=ADVANCED%20SECURITY&release_name=&majorRel=12.4&state=:HW:SW&type=Early%20Deployment
Hopefully that is more helpful...
Good luck!
Also one factor to consider is the number of concurrent services you will run along with BGP (full routes) on a 2620 router
I have seen a 2621 router running into High CPU load when you have a lot of concurrent services running.
I would suggest considering an ISR router like 2800 or the 3800 if you plan to take full BGP routes.
Narayan
308
