Community Member
375-stack configuration
Dears,
I have 2 3750 switches required to be stacked. Is there commands to enable stacking ? if there please send me
1 ACCEPTED SOLUTION
Re: 375-stack configuration
No configurations are required for stack connection.
Just connect the stack cables which came along between the switches.
If you want a certain switch to be a master then you can set the priority
HTH, rate if it does
Narayan
1 REPLY
Narayan
156
