Webcast-Catalyst9k
3750-24-TS-S and 3750G12S-S
Does any one knows if these switches can have three password attemps and then switch is locked out? Where can I find specific documentation about this type of configuration? Thank you
Re: 3750-24-TS-S and 3750G12S-S
The switch will not have this behavior. You need to implement that on the AAA server (radius or tacacs)
The command login block-for command will deny logins for a defined period after successive failed login attempts. Also, the aaa authentication attempts login 3 will set a maximum login attempt of 3. See all info here.
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080455b93.html#wp1046668
HTH. Pls rate all posts.
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
162
