Webcast-Catalyst9k
3750-24T-L randomly reboots without a cause
We have a WS-C3750X-24T-L switch that has 2 300W power supplies installed that is randomly rebooting its self about once a week. It is connected to a UPS, we have confirmed that the UPS and line power have not been interrupted at any time when the switch restarts. The logs show the switch was: Last reset from power-on. We have flipped the supplies positions in the switch and it still reboots. I have attached the output from running show tech.
Any ideas what may be going on?
First off, I am trying to discard bug CSCtw50892, in which the switch shows "power-on" no matter what the actual cause is.
If there is a crash or anything, this bug does not allow us see the actual last reset reason.
Could you reload the switch via console out of business hours?
Switch#reload
Proceed with reload? [confirm]  <<< (press enter)
Thereafter, you should see the following when typing "show ver"
Router uptime is 3 days, 18 hours, 39 minutes
System restarted by [reload cause]
System restarted by reload or system returned to ROM by reload
Let me go through the show tech and get back to you.
Kind regards,
- Ed
Ed,Thanks for the tip we can
Ed,
Thanks for the tip we can do that. I will let you know what the results are.
63
