3750/3560 12.2-53 LM images
so what, exactly is the difference between the standard 12.2-53 packages and the 'lm' packages for 3750/3560's?  According to release guide, it's to address the 16MB limit on flash, but what exactly is the difference?  I can't find a side-by-side comarison between the two.
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: 3750/3560 12.2-53 LM images
According from the release note, the LM image has device manager Express Setup file only, instead of the full web front end files (Table 4 of the below link). BTW, these two features are only available via the tar file image.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3750/software/release/12.2_53_se/release/notes/OL21141.html#wp841480
HTH,
jerry
Thanks for the reply.
I don't have partner access to cco, so the posted link does not work for me, is it similar to:
http://www.cisco.com/en/US/customer/docs/switches/lan/catalyst3750/software/release/12.2_53_se/release/notes/OL21141.html
That's what I thought from the preliminary research I've done.  I was just primarily concerned about core IOS differences.  Thank you for helping me, I appreciate it!
1100
